spare time toys
Dec 30 2005, 10:50 AM
I was told they are off an 85, 911 here are the photos of the markings.
spare time toys
Dec 30 2005, 10:52 AM
Any ideas as to what they are S or M or what
how do I tell
spare time toys
forgot this side
SLITS
Dec 30 2005, 10:59 AM
Larry....Porsche doesn't put part numbers on their calipers for the most part, except for some Brembos.
If the spacing is 3.5"....they would be "M" more than likely....The only "S" calipers I know of are aluminum.
Shoot an image of the top too!
goose2
Dec 30 2005, 12:13 PM
Isn't m 3 inch... a and s 3.5?
SLITS
Dec 30 2005, 12:22 PM
Damn Krauts...can't they follow the alphabet
You're prolly correct...........
736conver
Dec 30 2005, 12:39 PM
Somewhere in the mid late 70's I thought everything went to 3.5" Those look like carrera front calipers. Which I believe would need a thicker rotor.
spare time toys
Dec 30 2005, 07:07 PM
QUOTE (SLITS @ Dec 30 2005, 11:59 AM) |
Shoot an image of the top too! |
Here is the top. they are not alum. I checked with a magnet.
spare time toys
Dec 30 2005, 07:08 PM
view of the bot.
spare time toys
Dec 30 2005, 07:12 PM
I do know they dont open up enough for these rotors
davep
Dec 30 2005, 08:10 PM
Well, you really need to provide some dimensions: bolt hole spacing, length of pad and width between the pistons. Even the width between the pads will help.
They look like an A caliper which is a cast iron S size. I don't recall the brake line inlet there though.
TimT
Dec 30 2005, 08:13 PM
I was just going to post about the inlet for the brake line. I havent seen a 911 caliper that connects in that fashion. But then I havent seen all iterations of 911 calipers.
Eric_Shea
Dec 30 2005, 08:20 PM
Those are A-Calipers. 3.5" spacing and steel (cast iron, sorry Dave)
And... that would have been the correct caliper for what they said they came off.
spare time toys
Dec 30 2005, 08:44 PM
QUOTE (Eric_Shea @ Dec 30 2005, 09:20 PM) |
And... that would have been the correct caliper for what they said they came off. |
Thanks Eric
Yep 3.5 space sorry I forgot to put that in here. Wanted to be sure I got what I was supposed to get.
