sk8kat1
Dec 30 2005, 11:39 AM
I am new w/ a 914 and don't want to burn up the engine.. what is the top highway crusing speed for a stock FI 2.0 ?
I commute about 55 mi each way to work and it's all highway
thanks
Allan
Dec 30 2005, 11:42 AM
I could cruise all day at 70 - 80 in my 2.0 until something besides the motor broke.
SLITS
Dec 30 2005, 11:48 AM
Stock rolling diameter tires (25.4")....3200-3400 RPM....80-90 MPH....it hums there (don't get any ideas Aaron).
Dec 30 2005, 12:05 PM
QUOTE (sk8kat1 @ Dec 30 2005, 09:39 AM) |
what is the top highway crusing speed for a stock FI 2.0 ? |
3800 RPM ...
Andy
sk8kat1
Dec 30 2005, 12:30 PM
excellent then my normal habit of 80 plus a bit won't burn it up ...
JmuRiz
Dec 30 2005, 12:36 PM
Mine is a 2.0 with weber 40s and a mild cam...it really doesn't like to be below 3000rpm but it can do it. It's happiest at ~75mph in 5th.
redshift
Dec 30 2005, 12:42 PM
You are likely to burn a motor up under 2500 than you are at 4500. Lugging is head death.
There is a sweet spot, in fifth, @ around 37-3800, stock, where the engine is belting out horses, and perfectly happy to do so until you run out of gas, or road.
M
TravisNeff
Dec 30 2005, 12:49 PM
I am with slits, 80-90 indicated with 1.7 and do 40 mile round trips each day (daily driver).
rpmmaxxed
Dec 30 2005, 01:14 PM
my '73 with opened up exhaust and, cheap CAI, and the 1.7 will sit at 85 at 3900, and be happy. Never given me a problem.
sk8kat1
Dec 30 2005, 01:58 PM
actually I have just had her about 2 months -- I frogot she has burchst ( sp?) exhaust too I am assuming this helps my cause too
Dec 30 2005, 02:20 PM
QUOTE (redshift @ Dec 30 2005, 10:42 AM) |
There is a sweet spot, in fifth, @ around 37-3800, stock, where the engine is belting out horses, and perfectly happy to do so until you run out of gas, or road. |
Brando
Dec 30 2005, 03:07 PM
When cruising on the highway I keep it at about 3400-4000 rpms.
Most of the time when driving on the street I'm bouncing between 3800 and 5000 rpms. That's what the lower gears are made for
smg914
Dec 30 2005, 04:32 PM
QUOTE (sk8kat1 @ Dec 30 2005, 10:30 AM) |
excellent then my normal habit of 80 plus a bit won't burn it up ... |
"No problem what so ever"
Joe Ricard
Dec 30 2005, 06:39 PM
3400 RPM for me equals 80 MPH thats where it seems happiest. 195/60-15 rear tires. ZD 5th gear
SGB
Dec 30 2005, 10:09 PM
With my 205/50 tires, I'm at about 3K for 60 mph, which is OK i think for low-load highay cruising. On the I-state, 70 is right where the power comes in, so buzzing along at 75 is easy, and I can run up to 90 or faster really quickly. In fact, i've wondered what the top end is. I believe it would be RPM limited. Maybe 115 or 118?
