opera guy
Dec 30 2005, 05:33 PM
long time no post, been lurkin a bit, ... anyway, love my 914 still, but a new problem is buggin me. it seems after about 20 freeway miles in fall/winter here in so cal, my car has problem idleing. say, if im going about 60-70mph on the freeway, for 20 or more minutes, and i exit, by the time im at the end of the exit, im in neutral, car supposed to be idling at about 1k rpm, but, it just dies. im temporary "fixing" or "dealing" with this by blipping the gas while braking with the left foot.
car idles fine when its cold, any hints?
thanks
Allan
Dec 30 2005, 05:37 PM
Carbs or FI?
opera guy
Dec 30 2005, 05:40 PM
FI.. (dont even suggest going carb.
r_towle
Dec 30 2005, 05:48 PM
check your mps and see if it holds a vacuum.
Mine did not, same symptoms.
Rich
bd1308
Dec 30 2005, 05:58 PM
do you have a decel valve?
b
Cap'n Krusty
Dec 30 2005, 06:10 PM
"Idles fine cold"? Idle should remain high (1500 RPM or so) for 3-5 minutes before settling down to 1K. If it doesn't, you need to test and repair/replace the AAR. Points can cause this problem, as can a worn out breaker plate, the thing the points mount on. A rich mixture, and even a lean one, can cause this. As was already said, check the MPS to see if it holds vacuum. The Cap'n
opera guy
Dec 30 2005, 06:14 PM
how do i check if the mps is holding vacuum?
opera guy
Dec 30 2005, 06:15 PM
where is the decel valve? i dont know where it is.
ThinAir
Dec 30 2005, 07:55 PM
If it idles fine cold, but not when it's warm then the FIRST thing to check is your valve adjustment. Odds are pretty good that your valves are too tight. Almost everything else that it could be will cost you money, but this is free (if you do your own). Besides, a lot of the other things that it could be depend upon proper valve adjustment or they won't be right either. Start with the basics, then look for more complicated things if it doesn't help.
hotdgr
Dec 30 2005, 09:00 PM
QUOTE (ThinAir914 @ Dec 30 2005, 05:55 PM) |
If it idles fine cold, but not when it's warm then the FIRST thing to check is your valve adjustment. Odds are pretty good that your valves are too tight. Almost everything else that it could be will cost you money, but this is free (if you do your own). Besides, a lot of the other things that it could be depend upon proper valve adjustment or they won't be right either. Start with the basics, then look for more complicated things if it doesn't help. |
Good advice, Ernie
Allan
Dec 30 2005, 09:03 PM
QUOTE (hotdgr @ Dec 30 2005, 07:00 PM) |
Good advice, Ernie |
opera guy
Dec 31 2005, 07:25 PM
will definately do the valves. thanks for that reminder.
how do i check the mps's vacuumness?
bd1308
Dec 31 2005, 07:27 PM
pull 15psi on the mps port from a vac pump thing from FLAPS.
if it holds for 5-10 minutes with minimal/no bleed-down then you're set.
b
vesnyder
Jan 1 2006, 08:43 AM
I have the exact same issue - will check the valves, among other things!
Bleyseng
Jan 1 2006, 10:29 AM
and check your timing
