Aaron Cox
Dec 30 2005, 10:41 PM
installed 911 sender into motor today to work with 904 gauge......
old one had a spade lug...this hasa "glow plug?????"
sender on right!
jim_hoyland
Dec 30 2005, 10:44 PM
How aboub soldering a tail onto it ?
JoeSharp
Aaron: Don't the bayonet conectors fit over that?
:PERMAGRIN: Joe
TimT
Dec 30 2005, 10:45 PM
Grasshopper,
connection is made with same connector
Sometimes the connector is bent 90 deg. but the usuall spade connector fits
Aaron Cox
Dec 30 2005, 10:50 PM
QUOTE (TimT @ Dec 30 2005, 09:45 PM) |
Grasshopper,
Sometimes the connector is bent 90 deg. but the usuall spade connector fits |
how does a spade fit the glow plug thing on the right???
AA
John
Dec 30 2005, 10:56 PM
It slides on with the slot of the female spade connector toward the body. See the small diameter pin below the flat head? The pin fits in the slot of the connector.
Does that help?
Aaron Cox
Dec 30 2005, 10:57 PM
QUOTE (JOHNMAN @ Dec 30 2005, 09:56 PM) |
Does that help? |
i think i get it.... but i think i need a pic...
wait... pretty sure i get it...
TimT
Dec 30 2005, 11:00 PM
hmm ok it gets bent 90 deg and then fits over the sender
you gonna make me go out in the cold and take pics? (which I wont do tonight anyhoo)
I know you are a studying engineering... look at greatest dimension of those eletrical connectors
Make it fit.. it will work.. nothing special is needed to use that sender
Aaron Cox
Dec 30 2005, 11:01 PM
QUOTE (TimT @ Dec 30 2005, 10:00 PM) |
Make it fit.. it will work.. nothing special is needed to use that sender |
you tease... go take a pic...now.
head hurtz....thinking hurtz....
jim_hoyland
Dec 30 2005, 11:03 PM
Aaron, When you going to test it with the 904 gauge ?
Aaron Cox
Dec 30 2005, 11:05 PM
QUOTE (jim_hoyland @ Dec 30 2005, 10:03 PM) |
Aaron, When you going to test it with the 904 gauge ? |
maybe tomorrow. it is the sender for the 911 gauge...shouldnt be an issue.....
my temp wire disapeared...so i need to make a new one. need 14ga green and some heatshrink/heatshield
TimT
Dec 30 2005, 11:07 PM
Yikes Aaron. take any spade connector and just slide it over that "glow plug" thing...
usually the connector is bent 90 deg, so the harness is neater
Aaron Cox
Dec 30 2005, 11:08 PM
i get it now.
sorry for being dense....
why dont they just put a spade connector!
sorry....and thanks....
North Bay 914
Dec 30 2005, 11:41 PM
What rating was the original, and what is the one you put in? I think mine in my 74 is a 200, and the other is a 150.
Aaron Cox
Dec 30 2005, 11:42 PM
QUOTE (North Bay 914 @ Dec 30 2005, 10:41 PM) |
What rating was the original, and what is the one you put in? I think mine in my 74 is a 200, and the other is a 150. |
for a 911 300F gauge....
works with this gauge
North Bay 914
Dec 30 2005, 11:59 PM
The one in the right side of the photo, does it read 150 max?
ArtechnikA
Dec 31 2005, 04:22 AM
QUOTE (Aaron Cox @ Dec 31 2005, 01:08 AM) |
why dont they just put a spade connector! |
1) the engine moves a bit especially on stock mounts. the terminal is thus free to rotate on the sender rather than stressing the wire.
2) the terminal always attaches exactly the same way no matter how the threaded sender happens to index into the case.
why would you do it any other way? oh yeah - straight push-on terminals are cheaper...
Aaron Cox
Dec 31 2005, 10:37 AM
QUOTE (North Bay 914 @ Dec 30 2005, 10:59 PM) |
The one in the right side of the photo, does it read 150 max? |
yes
