toon1
Jan 2 2006, 12:32 PM
Hi guy's I have what I think is a gally plug that is leaking. looking at the front of the motor it is on the right side behinde the motor mount. It has an allen socket in it, can this be removed and sealed?
Allan
Jan 2 2006, 01:41 PM
Sounds like someone had them drilled out and tapped. I had the same thing done to mine but sealed the threaded plugs with JB Weld.
No leaks...
bd1308
Jan 2 2006, 01:44 PM
wait....
how many points does it have...if its 12, its the plug for the oil thingy that regulates oil pressure. that is, if you mean right side of engine with the fan facing you.
b
toon1
Jan 2 2006, 01:59 PM
with the fan facing me it is the right side behind the motor mount, it is a standard allen socket hole. It looks to be a add on, but not sure. thanks
