736conver
Jan 2 2006, 03:57 PM
Just install my getty dash. I dont think I can get that seal back on the bottom the way the dash is. In fact I had to take it off to get the dash to go in.
What does this seal do. Is it just a cosmetic thing?
Aaron Cox
Jan 2 2006, 04:20 PM
QUOTE (736conver @ Jan 2 2006, 02:57 PM) |
Just install my getty dash. I dont think I can get that seal back on the bottom the way the dash is. In fact I had to take it off to get the dash to go in. What does this seal do. Is it just a cosmetic thing? |
keeps the vinyl from coming up i think?
736conver
Jan 2 2006, 04:23 PM
I was thinking along those lines. I cant imagine what sealing purpose it would have.
Jan 2 2006, 05:39 PM
QUOTE (736conver @ Jan 2 2006, 01:57 PM) |
I dont think I can get that seal back on the bottom the way the dash is. |
mhmmm, my getty dash fit under that seal without any trouble ...
Andy
736conver
Jan 2 2006, 05:54 PM
QUOTE |
mhmmm, my getty dash fit under that seal without any trouble ... |
Maybe mine was made a little wider. Does yours go all the way to the edge like mine. Also did yours have the tabs the bend over the sub dash. This was the first getty dash I have seen with the tabs.
Jan 2 2006, 11:12 PM
installed ...
Aaron Cox
Jan 2 2006, 11:14 PM
got enough gauges???
whats the oil tank read with a /4
and 2 temp gauges
Aaron Cox
Jan 2 2006, 11:31 PM
very cool..... very cool....
oh i planned ahead....got a 904 gauge
736conver
Jan 2 2006, 11:44 PM
Andy,
Your dash sits alot lower then mine. Mine sits flush with the lip that the seal goes on. I see by your pictures you have plenty of clearance, clarence. Thats a roger, roger.
So is this a needed seal or cosmetic.
Anyone........Bueller...........
Jan 2 2006, 11:48 PM
QUOTE (736conver @ Jan 2 2006, 09:44 PM) |
So is this a needed seal or cosmetic. |
i don't know. does the glas sit on it? if not, i don't see why it would be needed ...
i put mine in before i added the windshield, so i'm not sure if the glas actually sits on the bottom part of the seal ....
Andy
Rand
Jan 3 2006, 12:46 AM
QUOTE |
In my worthless opinion... NO, it is NOT needed.
Unless......
The cosmetic difference matters to you.
You need concourse correctness.
And maybe another reason that someone else will post? Anyone?
I say do what you want. It is not structurally important.
Rockaria
Jan 3 2006, 01:50 PM
I believe it's cosmetic. But I put my Getty in without removing the windshield. Slipped right into place and I used a rubber knife to gently get the seal on top.
http://lib.nmsu.edu/~clandt/914/gettydash/index.htmlYou might want to put it in. I think the install will look bad without a seal there.
Cool!
736conver
Jan 3 2006, 02:00 PM
I would put it on/in if it would fit. But it just doesnt. My picture above is gone now. But you can see in my new one below that my dash fits right on top of where the seal goes. I thinking the bolts that were glassed into the dash where put in the wrong spot and thats why it fits so far back.
I think my fix is painting a border on the windshield. That will still give it a nice clean look.
