How do the lines connect between the tank, fuel lines and pump? There are two feed lines on the tank, two lines into the engine, and three on the pump, along with a T. Does the tank line go directly into othe pump, or does the line from the engine compartment connect directly to the pump? I suspect it is the engine small diamater line that goes back into the pump? Anybody have a schematic?
Thanks.
