Since I've got the conversion running I've been wondering about the accuracy of the oil temp gauge. I'm running the sender that came in the '85 3.2 and a gauge dated 4/80 which is probably from an SC. So since today I hadn't any great plans I decided to do a quick check to see how the gauge was "calibrated."
Here's what the gauge looked like when I stuck the sender in boiling water and allowed it to cool. A twenty-five degree F difference in temp is a pretty subtle change on this gauge. The particular tc I was using was reading 213 deg F in boiling water.
The car has been running right in the range that I tested which makes sense considering the 180deg t-stat.
There's a little parallax between the position where I took the digipix and the driving position but it's hardly worth worring about considering the lack reference marks away from the end of the "box".
Later,
Kevin
