dougcoup
Jan 3 2006, 04:09 PM
I am trying to sell 15 x 7 4 lugs off my 914 but the guy intrested wants them for a non porsche application.
Does anyone have an idea what the bold spacing is on the 4 lugs?
inches or mm
thanks
Doug
ArtechnikA
Jan 3 2006, 04:11 PM
4x130mm
like no other car made...
(ok - that's a little excessively bleak...)
4-bolt (IRS) VW's used that pattern too - with different offsets.
which makes sense, if you believe the 914/4 (VW Type 47) is an IRS VW in the rest of the world. if you don't believe that, then it's probably just a strange coincidence :-)
dmenche914
Jan 3 2006, 04:40 PM
yeah same as the later model air cooled Bugs, Ghia, etc.... The early air cooled cars used a wide five lug pattern.
Mueller
Jan 3 2006, 04:54 PM
the centerbore on the 4 lugs is 78.6mm for a little bit more info thrown your way...
for backspacing, just measure the distance from the hub face to the lip of the wheel.
lapuwali
Jan 3 2006, 04:55 PM
The very same "wide 5 lug pattern" also used on the 356, the 911, the 912, the...
ArtechnikA
Jan 3 2006, 05:22 PM
QUOTE (lapuwali @ Jan 3 2006, 06:55 PM) |
The very same "wide 5 lug pattern" also used on the 356, the 911, the 912, the... |
nah...
the 5x130mm "disk brake" pattern started with the 356C.
no 900-series car carried the drum-brake pattern ...
Cap'n Krusty
Jan 3 2006, 06:12 PM
QUOTE (lapuwali @ Jan 3 2006, 02:55 PM) |
Not all that many drum brake 911s out there, but I guess it's possible ............
The Cap'n
Dr. Roger
Jan 3 2006, 07:40 PM
QUOTE (ArtechnikA @ Jan 3 2006, 03:11 PM) |
4x130mm
like no other car made... (ok - that's a little excessively bleak...)
4-bolt (IRS) VW's used that pattern too - with different offsets. which makes sense, if you believe the 914/4 (VW Type 47) is an IRS VW in the rest of the world. if you don't believe that, then it's probably just a strange coincidence :-) |
strange coincidence.... funny.
Passats also.
heres some 4x130's you won't see every day...
carrol shelby made them....
on samba.com
http://207.58.142.82/vw/classifieds/detail...l.php?id=188573
bernbomb914
Jan 3 2006, 08:28 PM
post pics, maybe there is a buyer here. what brand and style?
Dr. Roger
Jan 3 2006, 11:25 PM
QUOTE (dougcoup @ Jan 3 2006, 03:09 PM) |
inches or mm
thanks Doug |
or 5.117 inches = 130mm =-)
dmenche914
Jan 3 2006, 11:57 PM
356's thru the B model used the VW wide five pattern, the 356 C was four wheel disc, and used the narrow 5 lug pattern as found on the early 911 cars, and the 914-6 cars. VW switched to the narrow 4 pattern likely when they started putting disc front brakes on Ghias, as the wide five didn't fit discs to well. One ponders why VW (and hence the 914-4) didn't use the same narrow five pattern as the 356C used back in 1965. That would have saved the need for five lug conversions of our 914-4's. My guess is that four was cheaper than five, and the four was considered enough for a VW's power.
dougcoup
Jan 5 2006, 06:13 AM
Thanks guys.
Won't fit his application 280Z Datzun
I thought these fit other euro cars from that era too.
