Since my offerings have changed somewhat, I figured I would update the post with the latest.
JWest Engineering Main Page
Here is a link to the old post with feedback: Old product post
First and foremost is the RennShift.
The most feature-packed Porsche shifter on the market (regardless of price).
$510.00 (Optional knob is extra)
Includes a complete shifter with:
20 or 33% reduced adjustable shift throw (can be user changed anytime)
Adjustable bias springs on both sides center the stick
Solid stops prevent trans and linkage damage and where and give a solid feel
Manual reverse lockout standard
Automatic reverse lockout standard
Can use stock knob with crush sleeve (our screw-on knobs available for extra cost)
Adjustable stick position
Versions are available fit side and tail shift 914s and 911s with 901 and 915 transmissions
Next is the rear trunk hinge pivot kit:
$80 for a pair
Durable, adjustable replacement for the rear trunk pivot.
Bolt-in replacement does not require welding to install. Back-up plate reinforces the mounting area.
The original pivot mount must be drilled or ground away and four new holes drilled for installation.
Strong, smooth pivot will not bind or gall as can occur with the original design.
Can be used with original torsion bars or aftermarket gas shocks see Camp914.
One kit does both sides of the car.
Also available is the blade fuse panel:
$95
Upgrade your Porsche 914 to modern blade-type fuses! Put an end to the corrosion problems of the original fuses.
No drilling required for installation. Requires no cutting of the original wiring. Bolts and plugs right in.
Kit includes: powdercoated mounting plate, fuse box, pre-installed fuses, fuse covers, and color-coded labels.
Labels supplied for each year of 914, and include fuse rating, circuits protected, and wire colors connected to that fuse position. Greatly increases troubleshooting ability over the vague factory symbols. Even the listing of fused items in the 914 owners manual is wrong for most 914s (it was never updated over the years). The last thing you need when troubleshooting electrical problems is additional confusion - solve that problem now!
The very popular fog light flash module:
$25
The way the car should have been wired. Signal other drivers easily with a flash of your fog lights using the column lever.
As an added bonus, once the kit is installed the fog lights can now be turned on with headlights off (if desired).
The 914 Fog Light Module is easy to install with no wire cutting and no modifications to the original harness.
Operation: When the headlights are off and the column stalk (turn signal lever) is moved toward the driver, the fog lights are turned on as long as the stalk is held. When the stalk is released, the fog lights turn off.
When the headlights are turned on, the stalk toggles the high-beam headlights on and off as usual.
This item works with all years of 914/4 (does not work with original 914/6).
Engine mounts for side-shift 914/4:
$30 a pair
Aluminum or hard nylon.
Includes new hardware.
Brake system products:
Brake line "T" fitting for German "bubble" flare fittings.
$10
Brake proportioning valve with rotary knob adjustment. 10mm bubble flare fittings.
$80
