leak ...
check fluid level first, but i'm pretty certain it's leaking somewhere.
check on the floor around the pedal cluster, a failing master cylinder can actually leak inside the car.
check on all 4 brake calipers.
check the master cylinder from under the car. you'll have to remove the protective shield that covers the front suspension.
Andy
