solex
Jan 5 2006, 01:59 PM
Hello All,
I have a problem with my throttle valve sticking, I took the throttle body completely apart and lubricated the shaft with some lithum grease (which seems to help), but thought that it would be much more accurate if the shaft was in a bronze bushing instead of the aluminum body which now has some play in it.
I did a search and it appears that someone used to do this, but the web page is no longer up. Has anyone else tried to add a bushing to the throttle body?
Thanks,
Dan
John
Jan 5 2006, 02:44 PM
I thought it was a member here named cooltimes...... (aka Mike Cooley)
solex
Jan 5 2006, 03:16 PM
I tried emailing Mike both his email address is no longer valid...
lapuwali
Jan 5 2006, 03:22 PM
Most any local machine shop should be able to do this.
airsix
Jan 5 2006, 05:38 PM
Mike hasn't done these for probably 5-7 years. I believe he sold off the tooling used to do the rebuilds.
-Ben M.
70Sixter
Jan 9 2006, 09:11 AM
If you cannot find anyone local, the guy is highly regarded.
http://www.eurometrix.ws/
