Andyrew
Jan 6 2006, 04:53 PM
Workin my f/g flares.. Laying some fiberglass and the resin doesnt want set.
Instructions say it should set in 20 mins..
Its been 2 hours, and its still wet.
Some of it is hard, and some other stuff is hard as well, but most of it is pretty bad.
Any suggestions? Im going to let it sit over night and see what it does.
Andrew
sj914
Jan 6 2006, 04:57 PM
Did you mix the hardener/activator thoroughly?
Temperature affects cure time as well.
m.monge
Jan 6 2006, 04:59 PM
did you put enough hardener in the resin. and if you did, did you mix it well enough? other than that all I can think of is maybe it's too cold/not enough sunshine to cure yet? I cant think of anything else. Good luck.
alpha434
Jan 6 2006, 05:05 PM
Yeah. I guess climate control is REALLY important for that stuff. Humidity affects dry time
tdgray
Jan 6 2006, 05:08 PM
My guess Andrew is that you either did not mix the hardner well or you put in too little or too much. Yes too much will make it not react appropriatley as well.
If all else fails give it a viagra
Strip it out and start over.
McMark
Jan 6 2006, 05:16 PM
It's freezing, yo. Put it in the sun or in the house with the heat cranked up (smelly).
Or just wait a long time.
spare time toys
Jan 6 2006, 05:17 PM
Heat lamps
We use them on flap repairs to speed up cure times when we gotta fly in the AM
tdgray
Jan 6 2006, 05:18 PM
QUOTE (McMark @ Jan 6 2006, 07:16 PM) |
It's freezing, yo. Put it in the sun or in the house with the heat cranked up (smelly). ;) Or just wait a long time. |
It's freezing in Modesto????
Did I miss the bulliten where hell froze over too.
redshift
Jan 6 2006, 05:22 PM
Bad mix. A test mix should get hot in 5 minutes.
I DO feel your pain. What a farggin' mess.
M
Andyrew
Jan 6 2006, 05:31 PM
Its about 70 where I was working.
I might have used to much resin (I wanted it to dry fast because I was working upside down.. gravity not friend)
I think the resin that I had went bad (or the hardner)
So I mixed another batch of resin correctly and went over the semi hard stuff with it.
I'll come back after work (at 1am
) and see if its hard. If its not, i'll strip it out.
No pics.. It will all be posted at once.
Andrew.
andys
Jan 6 2006, 06:37 PM
QUOTE (Andyrew @ Jan 6 2006, 03:31 PM) |
I'll come back after work (at 1am ) and see if its hard. If its not, i'll strip it out.
Andrew. |
If you have a container of polyester resin of unknown age, always do a test sample in a cup first.
It's usually best to start with fresh materials because as you may (?) find, it's a lot of trouble to deal with the alternative.
Andys
Pugbug
Jan 6 2006, 07:19 PM
Resin has a limited shelf life...The cobalt in it deteriorates over time. Always better to use fresh resin.
dmenche914
Jan 6 2006, 09:22 PM
Ditto on the comments about expired resin / hardener, they do have a shelf life.
Suggest if it is not hardening correctly that you will have ot strip it all off, you don't want incorrectly cured resin as a base, as it will propably cause problem later, like lifting or bubbling,
Sorry, good luck
PS be sure you have good ventalation, some of that stuff is none too good to inhale.
Also adding extra hardener (thats what you meant I assume) to speed up the reaction may not be too good a plan. It can speed it up, but, more heat is generated faster, so warping/expansion can be an issue, and often the end product is too hard, hence more brittle and may more likely crack later.
really best to stay within the manufacturers limits on mix, shelflife and temperature.
Pugbug
Jan 6 2006, 09:44 PM
Another safety tip when using the hardener....Use goggles because one tiny droplet in your eye and you will never see out of that eye again...It cannot be rinsed out!
Katmanken
Jan 6 2006, 10:40 PM
Go to a boat supply store and bring an empty milk jug.
Buy one gallon of fresh resin from thier drum in the backand take it home and do it right. Buy their hardner in the fridge too.
Resin is thermoset. Not sure if the new stuff will cause the old stuff to set up. Have tried it with no luck before.
Ken
Pinepig
Jan 7 2006, 12:12 AM
QUOTE (Pugbug @ Jan 6 2006, 07:44 PM) |
Another safety tip when using the hardener....Use goggles because one tiny droplet in your eye and you will never see out of that eye again...It cannot be rinsed out! |
Yes it can, but acetone doesn't feel very good either.
Andyrew
Jan 7 2006, 03:38 AM
All good advice everyone! The fiberglass was under the fender so I dont care at all if it "lifts".
But I'll throw away the old resin and hardner and use the new stuff I bought this week.
Andrew.
Dr. Roger
Jan 7 2006, 04:07 AM
heat lamp 'till sunrise.
if it aint dry by then, start ripping.
sorry man. but it could have been worse...
Andyrew
Jan 7 2006, 04:09 AM
Oh yes, forgot to say, its dry and hard...
Gave it some good pulls and I didnt hear any cracks either. so I think its fine.
Thanks! More advice with working with this junk. erm I mean stuff is welcome!
marks914
Jan 7 2006, 05:55 AM
Remember that resin and hardener mixing is a chemical process. The resin cures, not dries. I usually use a little more hardener or MEK than reccomended. Aheat gun can also speed up the process. Test first!
Mark
URY914
Jan 7 2006, 06:10 AM
If you use a colored hardner (tinted, not clear) it is easier to gage the amounts. This is when you just mix up a small batch without measuring everything.
I use a red MEK that is messy stuff (it NEVER drys up or goes away) but I don't have to measure and it works well.
IronHillRestorations
Jan 7 2006, 10:02 AM
So I mixed another batch of resin correctly and went over the semi hard stuff with it. |
Not gonna happen. If the new stuff sets up properly then you are going to have junk underneath. Hog the crap out and start from scratch!
Free advice? ALWAYS test your fiberglass epoxy before you get into the project. Mix a small batch (in the exact proportions) and make sure it sets up before you start slathering it on your 914!
Mueller
Jan 7 2006, 11:26 AM
Hey Andrew or Dan,
I need to drop off Sherryl in Manteca for a few hours today around 2:00, mind if I swing on by to check out the progress on the car??
dan10101
Jan 7 2006, 11:31 AM
QUOTE (Mueller @ Jan 7 2006, 09:26 AM) |
Hey Andrew or Dan,
I need to drop off Sherryl in Manteca for a few hours today around 2:00, mind if I swing on by to check out the progress on the car?? |
Hi Mike,
I'll be around, putting my engine together. Andrew may or may not be here. He has a winter formal to go to tonight. I don't know what his schedule is.
Feel free to stop by. Glad to have the company.
Dan
I'll PM my numbers in case you want to call.
dan10101
Jan 7 2006, 11:36 AM
Thanks to everyone for the advice, It's been years since I did any fiberglass work. And that was on a wooden boat. It eventually separated into pieces almost leaving my BIL stranded at the bottom of the lake. He made it back to the dock with the 283 blasting under full throttle and water sloshing over the back of the boat. Must have been quite a site. I'm glad I wasn't there.
So Yes, Andrew needs all the good advice you can give on this matter.
We both really appreciate it.
Dan
