well it wasnt as bad as i was expecting , both jack tubes are dead , but the only rust is the jack tube points themselves,not even any rust in the hole behind the jack tubes and both tubes themselves are still in great condition, figure a patch about 5" by 5" should more than repair the areas should i go with deleting the jack tubes, also was a tiny rust spot at bottom rear edge of drivers door frame and a small streak about 8 inches by 1/2 inch at the front of pass side right below the front fender. could even restore the jack tubes - not sure if i really want them still tho, but altogether less rust than i had been having nightmares over and a pretty easy repair:)
PO i guess tried to "fix" the covers with bondo and steel mesh - didnt seem to work tho lol- considering fabricating SS lines to replace the rubber fuel lines in order to maybe make the rockers fully sealed to the body
pics will have to wait til end of the month when i get a new digital cam
