Ok, the 6 is bolted in (a very cool CIS 2.4). Everything is working out great, I have the oil plumbing going in fine. NOW, the question is how to connect the throttle cable.
The stock connection (one of those little balls mounted on a bell crank) is carefully wedged in between the velocity stacks and the CIS pump unit, only a couple of inches from the rear sheet metal. In the 914, the ball needs to be pulled toward the BACK of the car.
From what I can tell, the cable will need to be mounted behind the sheet metal, and then go through a hole to the linkage.
Can anyone share some ideas or pictures? I would really appreciate it.
