McMark
Aug 27 2003, 09:29 PM
I've noticed that my car makes the most power at 1/3 throttle. Any farther and it just bogs and makes even less power. Anyone know what that's all about? What's going on?!
redshift
Aug 27 2003, 09:52 PM
Overly rich, under-volt, dirty rotor, mis-gapped, shifted points...
What car?
M
ChrisFoley
Aug 27 2003, 10:13 PM
At what rpm? Carbs or FI? Did this just happen?
Bleyseng
Aug 27 2003, 10:16 PM
Something is big time wrong if that's the case. It should make the most power at full throttle. An engine is a pump nothing more, more air in more power.
Geoff
McMark
Aug 28 2003, 01:14 AM
Brad Roberts
Aug 28 2003, 01:15 AM
Pressure sensor.
B
ChrisFoley
Aug 28 2003, 05:49 AM
The TPS provides additional enrichment as the throttle plate is opening, until it stops moving. Does the car accelerate better while you are depressing the pedal, as opposed to constant position? If so then the problem is a lean condition, not rich.
I too lean toward the MAP sensor being the culprit, but I've never had that symptom with the D-Jet.
2teeners
Aug 28 2003, 05:59 AM
I'd suspect a fuel supply problem, maybe a clogged fuel filter, or maybe an intake screen clogged with rust.
seems like a leaky mps would be be in full rich position and run better as the throttle went down. and the TPS is for "accelerator pump" type enrichment, and would still work if the throttle were held in constant position.
but that's just my sense of it. i've been wrong plenty.
TheCabinetmaker
Aug 28 2003, 06:14 AM
Maybe its that Napa Valley wine in the gas tank? LOL
Seriously, Brad is probably right. Check fuel pressure and pull a vacuum on the mps. I just repalced one this week, and man, what a difference.
Bleyseng
Aug 28 2003, 08:36 AM
I think that its both electrical and MPS. I think the dizzy's advance is not working rightand the MPS is having problems. A bad MPS goes rich but a car in good tune will still drive ok not the greatest but ok. Plugs will be black too.
Put a vacuum testor on the MPS to see if it holds 15hg for 5 minutes. If it doesn't hold a vacuum its toast.
Install the dizzy when you get it and see the results.
Geoff
Brad Roberts
Aug 28 2003, 10:24 AM
Show us the vaccuum gauge you use Geoff.
B
Bleyseng
Aug 28 2003, 10:47 AM
I don't have the camera with me but I'll post a little tech article on "How to test one"
Geoff
ChrisReale
Aug 28 2003, 12:12 PM
I dont think you are supposed to re-gap the plugs if you use a Pertronix. They stay the same
McMark
Aug 30 2003, 12:23 AM
Got my rebuilt distributor today, looks very nice. I didn't expect it to come with trigger points! Of course they're not brand new -- they've been bead blasted. I haven't installed it yet, but DAMN the shaft is tight in there. Now I know what a distributor is supposed to feel like! I'll get it installed tomorrow of Sunday and see how things are.
Brad Roberts
Aug 30 2003, 12:24 AM
Mark..
can you stop by this weekend ?? I'll be around all day Sunday and Monday.
B
McMark
Aug 30 2003, 12:25 AM
Forgot the image...
