I have a semi tube 914 with a 2.8, weight just under 2K, and a pretty trick suspension set up. Home track is Summit Point, WV, with summer temps usually 95+.
Last year I ran 225's and 245's on 7 & 8 X16 Fuchs. Would consider myself lucky if I ever saw tire temps at 161 with hot tires at 34psi.
I talked to one of the Michelin guys that works for Michelin. His suggestion was to mount 225 and 245 on 8 & 9 X 16. His reasoning was to keep the sidewall as straight as possible and that would help keep the tred parallel to the track. Start at 30psi hot and work down. I settled on 28 hot.
I'm a de guy, last year I had 19 days with the usual 4 sessions a day. I could have used the tires this season without a problem.
Being a person that can't pass up an opportunity to spend money I bought another set of Cups and had them shaved and heat cycled and installed them on 8's and 9's.
Tires are wearing even better than last years with 14 track days on them.
Feed back from other drivers and my experience is they are slightly slower than Ho's. The good news is they do not go away and wear is excellent.
I'll buy them again (in 2 years
) or I have another itch to spend money.
