KJJ-74-914
Jan 15 2006, 01:06 PM
I have a 1.8 converted with a larger Bore and Euro Pistons. Do I adjust the valves for a 1.8 or 2.0 engine?
I see the spec is the same. Never mind...thanks for looking though!!
Dave_Darling
Jan 15 2006, 02:46 PM
The spec is not the same. Valve gaps on the 1.8 motor are 0.006" for both intake and exhaust. The 2.0 motor, with its sodium-filled exhaust valves, uses a 0.008" exhaust valve gap, but the standard 0.006" intake gap.
Unless you found some (very rare) sodium-filled 1.8 exhaust valves, use the 0.006" spec just like a standard 1.8 does.
--DD
