d7n7master
Jan 16 2006, 09:31 PM
Hi All,
I need new grommets for the engine tin. Where can I buy them?
Part#'s???
Thanks,
d7n7master
Jan 16 2006, 09:32 PM
LH
d7n7master
Rear
TravisNeff
Jan 17 2006, 12:30 AM
McMaster.com has rubber grommets that go up to 1.5" ID
Andyrew
Jan 17 2006, 12:34 AM
You can always use rubber hose and cut it down the middle and fit it over...
Not as good as a grommet.. but it gets er done.
dmenche914
Jan 17 2006, 01:05 AM
look in an electical store, like Radio Shack, or Fry's, they have a selection of rubber grommets in all kinds of sizes. Orchard Supply also I think has them. (in the mics. hardware section). Otherwise scavenge at a wrecker, or check out a VW store ofr some of them (should be same as that on a bay window Type IV bus)
For that matter, check out West Coast Metric, they have engine rubber parts for VW's might have some 914 parts.
i have had good luck at the electronics or hardware stores.
good luck
Dave_Darling
Jan 17 2006, 03:30 AM
I've been able to order most of them (by part number) from Pelican. Helps if you have a copy of the PET or a factory parts manual...
--DD
maf914
Jan 17 2006, 08:08 AM
QUOTE (Dave_Darling @ Jan 17 2006, 01:30 AM) |
--DD |
Like Dave said, a copy of the PET will help you get the part numbers and you can take these to a VW dealer and order the parts from them. This is what I did and was able to get most of the grommets you have highlighted. I was lucky to have a friendly technician help me at the VW parts counter. He had to order all of the parts, I guess the T4 market has pretty well dried up.
jr91472
Jan 17 2006, 08:10 AM
I found suitable replacements at my FLAPS.
auggie91420
Jan 17 2006, 09:18 AM
Don't forget the plastic "cable-tie" studs that fit into the small holes at the top of the rear shroud that secure the starter cable. i was able to find NOS ones at AA, as I did most of the other grommets that you point out. Nice touch for just a few bucks.
type47
Jan 17 2006, 10:12 AM
i have THE most excellent grommets for the J tubes. $10 shipped. will try to post pix "soon"
Aaron Cox
Jan 19 2006, 08:23 PM
your close to santa ana?
mcfadden dale hardware
spunone
Jan 19 2006, 08:28 PM
Also a Mc Fadden Dale in Anaheim and Orange
Aaron Cox
Jan 19 2006, 08:29 PM
QUOTE (spunone @ Jan 19 2006, 07:28 PM) |
Also a Mc Fadden Dale in Anaheim and Orange |
and corona and ontario
auggie91420
Jan 28 2006, 07:20 PM
QUOTE |
QUOTE (auggie91420 @ Jan 17 2006, 07:18 AM) Don't forget the plastic "cable-tie" studs that fit into the small holes at the top of the rear shroud that secure the starter cable. i was able to find NOS ones at AA, as I did most of the other grommets that you point out. Nice touch for just a few bucks.
Huh? I think I may have clipped those puppiez off. |
I picked these up from AA about a year ago. The part number is B999 513 021 40. They hold the fuel line and battery positive cable to the rear shroud.
Rand
Jan 28 2006, 07:35 PM
Moot point now, but for future reference, any good hardware store should have a good selection of grommets.
914GT
Jan 28 2006, 07:54 PM
Also, Harbor Freight has a
grommet kit for about six bucks. Several sizes but the largest is only 1" ID.
