kdfoust
Jan 17 2006, 12:24 AM
I'm kinda browsing around for a used ZF type LSD for my 914 tranny. It seems I heard that 901/914 and 915 could use the same LSD. Is this true?
Regards,
Kevin
Aaron Cox
Jan 17 2006, 12:25 AM
QUOTE (kdfoust @ Jan 16 2006, 11:24 PM) |
Regards, Kevin |
ive heard that too... coarse spline ones i think.
believe you need special bolts to make it work.
KenH
Jan 17 2006, 01:45 AM
They are all the same except for the output splines. Early units had Course splines (18 I think) and later units had a Fine spline (like 40).
You can buy Course and Fine spline outputs from Guard transmissions. So a late 915 LSD can be converted to an Early 901.
Ken
KenH
Jan 17 2006, 01:49 AM
Oh the bolts. There are different bolts that are used to attach the Ring gear - they are available from Porsche.
Also the Ring to Pinon Backlass & Differential Preload have to be adjusted.
Ken
kdfoust
Jan 17 2006, 10:50 AM
QUOTE (KenH @ Jan 16 2006, 11:45 PM) |
Ken |
Thanks! You know I might just purchase the LSD from Guard and be done with it...
Later,
Kevin
