Full Version: Driver floor pan repair
Ferdinand
Hi, I'm new to this forum but I've had my 73 2.0 for 10+/- years. However, I'll admit that I don't know squat when it comes to Porsche/ VW, but I'll learn the hard way I'm sure. screwy.gif
I found significant rust in the small channel underneath the driver's floor. There is no channel on the passanger side. What is this channel for? I don't see where it has rusted through the floor and I planned on cutting and grinding it off and POR. Should I replace the channel or weld on a patch or replace the front floor? Thanks sawzall-smiley.gif
QUOTE (Ferdinand @ Jan 17 2006, 10:28 PM)
not sure what part you're talking about ...
i'm in Öakländ as well ...
beerchug.gif Andy
Ferdinand
The channel starts at the front pan that covers the rack and is about 12" long x 3" wide. It appears to be under the pedal cluster. Is this channel essential? BTW, it's a B taking a photo under the car on the ground. Thanks
McMark
It's a support for the pedal cluster. Keep an eye out for a car being cut up or post a classified ad. You'll be able to find a rust free panel. In the mean time, get some rust converter like Metal-Ready and just neutralize the rust for now. I wouldn't sweat it, but I would definitely replace it, if it were my car.
Jeroen
check your master cilinder for leaks
that's most likely the cause for rust in this location
also check the floor (inside the cabin) at the pedal cluster
QUOTE (Jeroen @ Jan 18 2006, 06:59 AM)
i think this part is to prevent flex on the floorboard near the pedal cluster ...
wink.gif Andy
