toon1
Jan 18 2006, 10:49 AM
I am getting ready to put my 1.7 back together. I can't seem to find piston rings for 90mm bore. Are the vw rings the same? Is it ok to clean the rings that are there break the glaze on the cyl. and reuse? will they reseat?
SLITS
Jan 18 2006, 11:46 AM
Deves Piston RingsGive them a call...scroll down the page to 914 1.7.......
toon1
Jan 18 2006, 01:54 PM
Thank's, I happened to find them @perf. prod. as well. they were about $12 cheaper than Deves.
What can I look for on the old rings to tell if they are still usable or not?
bd1308
Jan 18 2006, 01:58 PM
QUOTE (toon1 @ Jan 18 2006, 01:54 PM) |
What can I look for on the old rings to tell if they are still usable or not? |
i think you can tell if they're good or not by measuring the gap in the ring???
b
SLITS
If you want to reuse them, go ahead. There is really nothing to look for other than to stick them in the bore and measure the end gap.
MattR
Jan 18 2006, 02:01 PM
Remember, if you do replace rings you have to hone the cylinders.
toon1
QUOTE (SLITS @ Jan 18 2006, 11:58 AM) |
If you want to reuse them, go ahead. There is really nothing to look for other than to stick them in the bore and measure the end gap. |
what is a good end gap measurment?
SLITS
Jan 18 2006, 02:32 PM
The specifications will be given in the manual........
You should also check the side clearance in the ring land.
Bleyseng
Jan 18 2006, 04:19 PM
like this
toon1
Jan 19 2006, 11:20 AM
Anyone use autohausaz, Grant brazilian rings
toon1
Jan 19 2006, 01:03 PM
anyone.....anyone.....bueller....bueller........
Bleyseng
Jan 19 2006, 01:10 PM
I just put those on the 1.7L Blair and I are rebuilding. Haven't run it yet.
