After recently replacing the alternator, the headlights would only come on if I turned them on first before starting the engine.
Now, the headlights don't come on at all. All the running lights/blinkers work and the headlights do pop up but no light.
Read through the threads, so I checked the fuses (look good, replaced them all when I got the car in June) and replaced the relay but the headlights still won't come on.
What should I check next? How common is it for before bulbs to burn out at the same time? Also, when I try to turn on the high beams, I get nothing.
Confused what to do next.
Thanks in advance,
Vince
