Finished the semi tube frame front today and I'm pretty happy with how it turned out
First, I fabbed a crossbrace up front over the front a-arm mounting points
detail shot of the x-brace
welded in
next, I welded scab plates to the firewall and fabbed the upright braces
(these were a PITA to make)
for the bolt in diagonal, I welded little tubes into the upright braces to fit an M10 bolt
bracket of the diagonal brace
again, and the second bracket still in pieces
(3mm plate, M10 nut and piece of square tubing )
testfitting it to the upright brace...
feet welded to the diagonal and trimmed
finished...
upright braces welded in and the diagonal bolted in between
close up...
nother
the result...
I can jack up the left front and the right will follow along nicely
there's about half an inch deflection, but this is still without a cage
more detailed pics in my blog
(click the blog-button at the bottom of this post)
