I'm working on getting an AX competition set up for the 914 group
at the Historics. This is by no means a done deal as I have yet to contact the organizers or the SCCA rally folks (who do the work).
A bit of background. The AX has been set up in the infield Pro Pits. The Corrals are set up on the grass around the asphalt.
They are hand timed by the SCCA rally folks and I assume that will be the case again. The organizers charge 5 bucks a run...both days, all day....*for Charity.*. This will apply to all entries. We will need 4-8 volunteers to collect times. Pre-registration will be required before Sunday. There will be a seperate thread for registration.
The initial plan is to have the competition on Sunday between 10 AM & 3 PM. Each entry will have 3 timed runs. You can have as many practice runs as your wallet allows, but when you start timed runs (it's your decision as to when), the next 2 only count. Run times will probably be around 30 sec. or less.
Classes:
I wanna keep it simple.
1.7 to 1950ccs
2.0L to 2341ccs
2.5L & up.
All else is free.
If there is interest, a pure stock class can be added.
Rotarys will be per FIA rules for displacement.
This is all open to comment......as a matter of fact, this whole works is.
I need to know the number of folks within a few weeks.
The more money we can put into the charity's pocket, the better chance this has of getting airborne.
