Hammy
Jan 22 2006, 03:09 PM
When I roll up the drivers side window, it gets tougher to roll up and then about 3/4's of the way there's a "pop" and all the stress is gone for the rest of the way up. I can't figure out what it is. Something must be grabbing onto something. Is this common, anyone else had this?
Andyrew
Jan 22 2006, 03:14 PM
Take off the door pannel and look at the slider. Then lube everything up.. While your at it do the door handle/key mechanism.
redshift
Take off the door panel, and clean the mechanism.. sounds like you have a lil roller with a problem too.
M
Allan
Jan 22 2006, 03:15 PM
It may be the weasel.
They will do that sometimes...
goose2
Jan 22 2006, 04:13 PM
watch the rear top edge of the glass as you're rolling it up....somtimes it begins to track inside the targa bar rubber and binds...the fix is to adjust the bottom of the rear track inside the door
