thomas
Aug 30 2003, 08:03 PM
looking for the part# for mercedes 23 mm master brake cylinder
the 19 mm is too small for my brake setup
thanks for the help
Qarl
Aug 30 2003, 08:07 PM
Mercedes truck ATE part #3.2123-1003.3
What brakes are you running?
Oh.. and welcome to the board. Be sure to post pics of your car.
Regards,
Karl
thomas
Aug 30 2003, 08:10 PM
boxter front and m-calipers rear
Qarl
Aug 30 2003, 08:14 PM
A 19mm should be fine. Have you tried the 19mm? You would need the 23mm for 930 brakes, Big Reds with something big in the rear, a full Boxster Monobloc setup.
Monoblocs and Ms should be perfect with a 19mm.
If you are having issue, there might still be air in the system.
Wht about the proportioning valve? S till there? Or did you replace it with something else... a brake-T or an adjustable proportioning/brake bias valve?
Brake lines? Do you still have the rubber lines, or are they replaced with stainless lines?
Qarl
Aug 30 2003, 08:15 PM
Oh... and Smart Racing Products has the whole 23mm kit for $110 or something... MC, elbows, longer actuating rod, etc.
seanery
that seems like a very front heavy system to me.
thomas
Aug 30 2003, 08:30 PM
have all stainless brake lines , no brake bias,and bleeded the system with a power bleeder still have spoongy pedal i have too push the pedal about 3-4 inch for a solid feel
seanery
Aug 30 2003, 08:42 PM
If you pump the brakes 3 or 4 times do you get a hard pedal?
If so, bleed some more. If you replaced all that, it takes a loooooong time to get all the air out.
Qarl
If you still have a "spongy" feeling several things...
1. Air is still in the sytem. Bleed more.
2. The pads may have not bedded themselves in yet.
3. There could be air in the master cylinder if it was new/dry before
4. Bleed some more.
thomas
Aug 30 2003, 08:48 PM
thanks everybody will bleed the system more on sunday
Mueller
Aug 30 2003, 10:41 PM
Are the pads new? How much space do you have between the pads and the disc?
If space is too far (used pads or disc too thin) you might be running out of "reach" with the M/C.
Spacers can be placed between the pads and the pistons of the calipers to correct this sometimes.
Also, is the M/C new? I've seen brand new M/C's fail right out of the box.
