Rand
Jan 27 2006, 01:39 PM
Watching tractor pulls on ESPN2... The big alcohol-burning beasts are running three turbos, multistaged, pushing up to 100lbs of boost.
Aaron Cox
Jan 27 2006, 01:40 PM
top fuel dragsters are running like 70-90 i heard (supercharged)
alpha434
Jan 27 2006, 01:48 PM
yeah. They just weld the heads on. You can do that with our little engines and run 25, easy.
Aaron Cox
Jan 27 2006, 01:50 PM
QUOTE (alpha434 @ Jan 27 2006, 12:48 PM) |
yeah. They just weld the heads on. You can do that with our little engines and run 25, easy. |
how do you weld aluminum (heads) to steel (cylinders)?
alpha434
Jan 27 2006, 01:51 PM
get aluminum cylinders. Duh.
Britain Smith
Jan 27 2006, 03:55 PM
I wonder if Jake has ever tried that one?
-Britain
Jake Raby
Jan 27 2006, 04:04 PM
Nope...
Just do like a Lycoming and THREAD the heads onto the cylinders like a big pipe!
stock93
Jan 27 2006, 04:20 PM
Check out varible geometry turbos. Some of them are in the neighborhood of 70 lbs of boost with a single turbo.
John
Aaron Cox
Jan 27 2006, 04:23 PM
QUOTE (Jake Raby @ Jan 27 2006, 03:04 PM) |
Nope... Just do like a Lycoming and THREAD the heads onto the cylinders like a big pipe! |
hard to do with finned cylinders no?
Mueller
Jan 27 2006, 04:32 PM
QUOTE (Aaron Cox @ Jan 27 2006, 03:23 PM) |
QUOTE (Jake Raby @ Jan 27 2006, 03:04 PM) | Nope... Just do like a Lycoming and THREAD the heads onto the cylinders like a big pipe! |
hard to do with finned cylinders no? |
it would be easier if the cylinders are 2 piece...the cylinder screws into the head and the fins slide over the cylinders......sounds expensive
personally, I like the idea of the head and cylinder being one piece....harder to do a valve job, but doable and is currently offered as is for Type I light aircraft applications.....
Aaron Cox
Jan 27 2006, 04:39 PM
scat makes type 1/4 heads where they are individual heads....
slugmika had them on his bug
Mueller
Jan 27 2006, 04:41 PM
QUOTE (Aaron Cox @ Jan 27 2006, 03:39 PM) |
slugmika had them on his bug |
yea, I was looking at those, Jake talked me out of it...way too much work I guess?!?!?!?
Aaron Cox
Jan 27 2006, 04:44 PM
QUOTE (Mueller @ Jan 27 2006, 03:41 PM) |
QUOTE (Aaron Cox @ Jan 27 2006, 03:39 PM) | scat makes type 1/4 heads where they are individual heads....
yea, I was looking at those, Jake talked me out of it...way too much work I guess?!?!?!? |
but you could thread them into the cylinders
whats more work about them???
airsix
Jan 27 2006, 04:59 PM
When you turbo a typeIV all the boost goes past the rings.
Seal the rings and it goes out between the deck and heads.
Seal the heads and it goes out the valve guides.
And oil starts coming out of places that never leaked before.
...but its fun to drive.
-Ben M.
Porcharu
Jan 27 2006, 05:55 PM
QUOTE (Mueller @ Jan 27 2006, 02:32 PM) |
personally, I like the idea of the head and cylinder being one piece....harder to do a valve job, but doable and is currently offered as is for Type I light aircraft applications..... |
I was watching that too, I even thought about posting a WOT thread. They are converting heavy duty diesels to alcohol and then running compound turbo systems on them, mentioned going from a little under 200 HP to 4000HP!
Mike you need to look at an old OFFY they are made like that - that's why they were so succesfull as Indy car engines for so long. That's gotta be a PITA to do a valve job.
airsix
Jan 27 2006, 06:45 PM
QUOTE (srbliss @ Jan 27 2006, 03:55 PM) |
personally, I like the idea of the head and cylinder being one piece... That's gotta be a PITA to do a valve job. |
Compressing the rings and slipping all the pistons in is probably tricky too.
-Ben M.
r_towle
Jan 27 2006, 09:12 PM
QUOTE (Mueller @ Jan 27 2006, 05:32 PM) |
QUOTE (Aaron Cox @ Jan 27 2006, 03:23 PM) | QUOTE (Jake Raby @ Jan 27 2006, 03:04 PM) | Nope... Just do like a Lycoming and THREAD the heads onto the cylinders like a big pipe! |
no need for a cooling system on a 1/4 mile drag motor...
Look at pauter...he has some 1000hp motors...
They are a one shot deal...but if you win, its worth it I suppose...
Rich
