Always Looking
Jan 27 2006, 04:27 PM
I am replacing my front calipers with the BMW 330i ones based on a tech article at Pelican. I am going to have the rotors turned. Is there any reason to keep the protector? I have Riviera wheels and the protector scrapes the weights that are glued to balance the wheel. (so I bent the protector slightly out of the way).
Thanks in advance.
Mueller
Jan 27 2006, 04:30 PM
it's perfectly acceptable to remove them from the front and rear ...
tat2dphreak
Jan 27 2006, 04:31 PM
mine looked like damnit so I threw them away...
MartyYeoman
Jan 27 2006, 05:00 PM
I also did the BMW front brake conversion and I kept mine.
I had to trim around the caliper a bit. I think I removed about a quarter of an inch.
My opinion is they put them on for a reason.
Probably, to protect the calipers from excess dirt buildup from road grit.
I'd trim clearance for the caliper and weights and use them.
Jan 27 2006, 05:18 PM
QUOTE (Always Looking @ Jan 27 2006, 02:27 PM) |
Is there any reason to keep the protector? |
protection?
Porcharu
Jan 27 2006, 05:39 PM
Those things are intended to keep huge amounts of water off the rotors. Sometimes they hold gravel. Toss em'. None of my cars have them.
hmeeder
Jan 27 2006, 11:20 PM
They also hold in the heat from braking. Basically operate as heat reflectors. Without them you will get more airflow for brake cooling.
I removed all of mine (I seem to recall needing to remove the rear rotor when I removed mine.)
