Mueller
Jan 30 2006, 03:00 PM
As soon as I get the directions from McMark on how to use his
Caswell anodizing kit , I plan on trying it out.....any BTDT tips or tricks??
material will be 6061 and is 914 related
bondo
Jan 30 2006, 03:04 PM
Don't try to do large parts. Cast parts work sometimes but my results have varied. Avoid solution contamination. Use a chemical sealer if you can. Definitely practice on some scrap.
McMark
Jan 30 2006, 03:07 PM
Okay, okay. I'll write myself a note to get you the manual. Sheesh.
You didn't have to go "public" to get my attention.
J/K
But I did write myself a note.
McMark
Jan 30 2006, 03:08 PM
bondo
Jan 30 2006, 03:19 PM
I use a universal battery charger called a fair radio charger. It's military surplus. It can handle about 15 amps.
Porcharu
Jan 30 2006, 03:31 PM
Mueller
Aug 3 2006, 02:47 PM
Hey Mark....I got a powersupply
It just so happens I needed to buy a "good" for work...no problem for me to borrow it for home use,,,wanna bring the kit with you next week??
I think this is the very same question that got Dirk Wright started
HarveyH
Aug 3 2006, 06:25 PM
Clean!
Clean!
Clean!
Clean!
Clean!
Everything has to be very clean.
I assume you will be using aluminum rods to support your piece parts for processing; don't skimp and try and reuse them. Once they've gone in the tank and the current has been started they are anodized too; the really small contact points with the workpiece will not be, but you will never get them lined up properly to make a good contact.
If something happens and you have to take a piece out before it is done, it will have to be stripped, cleaned, and completely reanodized.
Most of what I did (20 years ago now...) was hot water sealing, with a couple of items in a chromate sealer so I dont know anything about them
Joe Bob
Aug 3 2006, 06:39 PM
CW clean.....get a "Tack Cloth"....
iamchappy
Aug 3 2006, 08:16 PM
Check Ebay auctions for Bdstone, he sells nice plated 914 parts for less than the effort
you have to go through doing it yourself.
McMark
Aug 3 2006, 10:16 PM
I'll pack it along. I was just trying to decide where to store it.
