pete-stevers
Jan 31 2006, 05:39 PM
Is there any noticable differences between the 2nd gen and later modle rennshifters....
i have an option to buy a 2nd gen shifter...or should i hold out for a new one?
JWest
Jan 31 2006, 06:16 PM
In the pivot, not a lot of difference in the feel (the newer is a little more positively located, but not enough to matter much when compared to the stock junk).
The new version allows you to change between 20 and 33% throw reduction, and has both manual and automatic reverse lockouts. You can also adjust the stick position side-to-side with the newer model.
If none of the ancillaries matter much to you, then go with the older version.
Aaron Cox
Jan 31 2006, 06:19 PM
ive driven and installed both....
to me? it alll about the 33% old style....
Kerrys914
Jan 31 2006, 07:32 PM
I have the old Skool gen 1 shifter. Do you have a polished stick for sale/swap/?
Cheers
pete-stevers
Feb 1 2006, 05:53 PM
does the early modle have manual lockout? or atomatic lockout?
what percentage throw does the early one have?
Kerrys914
Feb 1 2006, 06:52 PM
The gen 1 shifters;
- You selected your throw reduction when you ordered it.
- You bought a reverse lockout kit and added it (I guess that would be an auto lock out)
- Stiffer springes were offered to help with shifting ( I run stiffer springs on the R-1 plane.
Best upgrade to my 914 (no counting the SIX).
JWest
Feb 1 2006, 09:52 PM
QUOTE (Kerrys914 @ Feb 1 2006, 07:52 PM) |
The gen 1 shifters; - You selected your throw reduction when you ordered it. - You bought a reverse lockout kit and added it (I guess that would be an auto lock out) - Stiffer springes were offered to help with shifting ( I run stiffer springs on the R-1 plane.
Best upgrade to my 914 (no counting the SIX). |
Correct.
0% (I sold less than 10 of them), 20% or 33%. It was hard decision for many people and it was split on people that like one over the other.
Yes, it was auto lockout.
