alremley
Feb 4 2006, 04:43 PM
Steering wheel on my 75 moves up and down. I believe the crush bearing inside the column needs replacement.
Anybody done this?
Any special tips on this.
Allan
Feb 4 2006, 04:46 PM
I never tried to replace the bearing but I do know that Pelican and GPR sell poly bushings that is suppose to fix the wobble.
r_towle
Feb 4 2006, 05:17 PM
Did you check the bolts under the dash that hold the column in place...
If they are all tight...you need to bet that bearing..
PP sells them...
Take off the steering wheels, switches, and housing..you can get to it from up top.
Good luck
Rich
Allan
Feb 4 2006, 05:19 PM
If you do the bearing swap can you post pics.
Mines gonna need it fairly soon and I want to see what I'll be getting myself into.
solex
Feb 4 2006, 06:46 PM
It is a typical bearing with plastic sleve. The sleve usually goes and then you have the up and down play in the steering wheel. Ask me how I know this... I just replaced mine and it is the exact same bushing as a super beetle.
To replace it you need to remove the steering wheel and the housing (the ignition tumbler is in the housing) from the column and lower dash.
A snap ring holds the bearing in the housing. From my research Paragon has the best price a little over $9.00
Have fun,
Dan
messix
Feb 5 2006, 02:34 AM
same here. i'm gonna have to raplace both upper and lower bearings. crush sleeve didn't do it for me and found the upper bearing had alot of play and lower did too.
any body ever have the steering shaft u-joints wear out with some slop
Feb 5 2006, 01:19 PM
with all of the above. check the bolts first (4 of them) then check the sleeve. the bearing itself rarely fails.
btw., you can get the sleeve in metal as well, i like them better than the plastic ones ...
Andy
Lou W
Feb 5 2006, 10:16 PM
Automotion sells the part here;
Steering Column Bushing
joea9146
Feb 6 2006, 08:50 PM
So with this sleeve you aviod having to take everything apart ?
Am I understanding this correctly ?
Anyone use this sleeve ?
Feb 6 2006, 11:27 PM
QUOTE (joea9146 @ Feb 6 2006, 06:50 PM) |
Anyone use this sleeve ? |
not this *exact* sleeve, mine is metal, coneshaped with ripples.
they work like a "wedge", sitting on the shaft, wedged between the shaft and the bearing thus taking out any "slack" between the bearing and the shaft.
works very well ...
Andy
joea9146
Feb 7 2006, 06:42 AM
QUOTE (SirAndy @ Feb 7 2006, 01:27 AM) |
QUOTE (joea9146 @ Feb 6 2006, 06:50 PM) | Anyone use this sleeve ? |
works very well ... Andy |
Andy you remember where you got your sleve ?
Feb 7 2006, 11:55 AM
QUOTE (joea9146 @ Feb 7 2006, 04:42 AM) |
Andy you remember where you got your sleve ? |
yes, out of one of the cars we cut up when brad still had his shop in palo alto ...
sorry, i have no idea where it was bought ...
Andy
Dave-O
Feb 19 2006, 12:17 PM
I have never taken my column apart. Is the sleeve the same between the early and late cars? I see that Andy put one in his early car but I don't know what steering column he has in it?
Will this sleeve work on a 1970 column?
Feb 19 2006, 02:18 PM
QUOTE (Dave-O @ Feb 19 2006, 10:17 AM) |
Will this sleeve work on a 1970 column? |
yes, it'll work. the shaft dia. and the bearing are the same early/late ...
the sleeve is wedged between the shaft and the bearing, giving it a schnugg fit ...
Andy
Dave-O
Feb 19 2006, 02:24 PM
schweet! Cheers
