bd1308
Feb 6 2006, 07:58 AM
i've been tossing the idea around of doing a engine rebuild next year and wanted to ask you guys which engine people usually use.
I have a stock 1.7L with L-jet, but I think a nice 2056 or a tad bigger would be good...
what do ya'll think?
Sincerely,
Sir-Post-Alot
bd1308
Feb 6 2006, 08:00 AM
that is unless somebody has any idea to pep up my 1.7L
b
Jake Raby
Its ALL dependant upon what you have to spend!
How much ya got??
remember that the 1.7 is just as easy to make MassIVe as any other engine- my 3 Liter is based on a 1.7 case!
bd1308
Feb 6 2006, 08:04 AM
all of the /4 cases are the same arent they?
I ahve zilch now, but i plan to have a moderate amount by next year.
not 2056 crate engine money, but cylinder head money and what-not.
someday i'll get a raby engine, that is when I build my megasquirt.
b
bd1308
Feb 6 2006, 08:12 AM
so jake, lemme ask you something then.
for just "cruising" and long-distance driving, is it worth going to like a 2.x size?
I mean I would like my car to run reliably, but like you always say "it's all in the combo"
not asking for detailed info, just wondering if you have a small displacement good running engine idea in the form of a kit that could be purchased....
b
Joe Ricard
Feb 6 2006, 09:23 AM
Britt, ain't nuthin wrong wit yo 1.7L for kruzin. 32 MPG is really cool.
Didn't know 1.7 came with L-jet.
Looks like I sold my Early "W" case 1.7L to fund my 2056 screamer.
Bleyseng
Feb 6 2006, 09:27 AM
The costs to rebuild a 1.7l properly is almost the same as a 2056. The biggest cost is the 3 bolt heads although you could use a set of Jake's special heads instead.
Depends on how much hp you have to have as a 1.7 can be built to run better than stock & with more HP.
Mark Henry
Feb 6 2006, 09:30 AM
QUOTE |
/4 engine rebuild, what do people usually do? |
Buy a new hamster
(that one was for JP )
bd1308
Feb 6 2006, 11:46 AM
QUOTE (Joe Ricard @ Feb 6 2006, 09:23 AM) |
Britt, ain't nuthin wrong wit yo 1.7L for kruzin. 32 MPG is really cool. Didn't know 1.7 came with L-jet. Looks like I sold my Early "W" case 1.7L to fund my 2056 screamer. |
it didnt. I put L-jet on it because I was done with fooling with carbs.
You sold your heads too?
b
Jake Raby
Feb 6 2006, 01:12 PM
Sounds like you need a 2056 or 2270 engine kit.... Its the cheapest way to do it yourself, get a correct combo and get support to boot!
jetboy
Feb 6 2006, 02:49 PM
Hope this isnt hijacking, but, im also curious about the options for 1.7 build up. Is there any machining required to put in larger pistons/cylinders? Or is the 1.7 stuck with the stock size 90mm bores?
Joe Ricard
Feb 6 2006, 03:25 PM
Yea Britt I sold it as a super long block. which is Flywheel, oil cooler and probably some tin maybe a fan housing if I can talk him into taking it too.
Got another set of 1.7L heads probably serviceable haven't checked them out yet.
Jet Boy the case does not need to be modified but the 1.7L heads do need to be cut for bigger cylinders.
Trekkor
Feb 6 2006, 03:29 PM
What? I was hungry.
KT
Joe Ricard
Feb 6 2006, 03:31 PM
Trekkor you crack me up.
Maybe if I give Britt the parts AND drive them up to KY.
Jake Raby
Feb 6 2006, 04:03 PM
The 1.7 case is no smaller than the 2.0! To upgrade the 1.7 all you need are components from a 2.0 to drop right in, no machining required.
my 3 liter is based on a 1.7 case! I did it to prove the point that the 1.7 case is fine to modify.
tat2dphreak
Feb 6 2006, 04:43 PM
Britt, also think of the 1911 size, that will keep you from buying a 71mm crank, just standard 1.7/1.8 crank, 96mm pistons, 1.8 or 2.0 cylinders machined to 96mm , and the headwork...
just wanted to throw out another option...
the 1.8 bus motor I have in the corner will probably get the 1911 treatment when I get around to it...
Aaron Cox
Feb 6 2006, 05:14 PM
britt...
to go 2056 you need a 2l crank = money
to go 2270 you need a stroker crank, = more money....
do a 1911... its a 96mm bore with your 1.7/1.8 crank.
Mueller
Feb 6 2006, 05:21 PM
QUOTE (Aaron Cox @ Feb 6 2006, 04:14 PM) |
britt... to go 2056 you need a 2l crank = money to go 2270 you need a stroker crank, = more money....
do a 1911... its a 96mm bore with your 1.7/1.8 crank. |
i'd vote for the 1911 if money is an issue*, once you get $20K in student loans, then go the monster Raby motor
*even if money is not an issue, it's a good fun engine, heck, just even a stock rebuild will be more enjoyable that what you are currently driving.....just make sure you get a good cam from Jake...the megasquirt can handle anything you throw at it...you'll love your new motor...
lapuwali
Feb 6 2006, 05:29 PM
Subaru...
Mueller
Feb 6 2006, 05:31 PM
QUOTE (lapuwali @ Feb 6 2006, 04:29 PM) |
Subaru...
it's getting more and more tempting for me, especially since I no longer have a real time frame to get my car up and running
I'm waiting for Fiid to decide to go with a Subaru transmission so that I can buy his adapter stuff from him
sanman
Feb 6 2006, 05:34 PM
QUOTE (lapuwali @ Feb 6 2006, 03:29 PM) |
Subaru...
scotty b
Feb 6 2006, 06:00 PM
Tell him not me
Britt made me say it
bd1308
Feb 6 2006, 06:23 PM
no with the FI i was tired of running a tired 2.0 to the ground while running fuel injection which I had to jimmy rig till next weekend.
This L-jet starts right up, no problems albeit a little miss every now and then.
the 1911 is probably what i'll do. with a warm cam and MS. I have the 1.7L Djet setup ready for it.
Joe: wha?
is there really THAT much of a difference between the 1.7 and the 1911?
b
tat2dphreak
Feb 6 2006, 06:29 PM
QUOTE (bd1308 @ Feb 6 2006, 07:23 PM) |
Joe: wha?
b |
if you make the 1911 with higher CR, better cam and MS there will be a BIG difference...
Jake Raby
Feb 6 2006, 06:35 PM
My 1911 combo makes MORE power than a stock 2.0 and runs cooler! I'll make you a sweet deal on some 1911 parts- they need to go and have been slow movers lately.
Mueller
Feb 6 2006, 06:38 PM
QUOTE (bd1308 @ Feb 6 2006, 05:23 PM) |
b |
everything being equal, the 1911 should have a 10% increase in power over the 1700...going with a Jake combo, it'll be way more than that...you'd be silly to opt for anything else unless you go with a monster motor from him...
bd1308
Feb 6 2006, 06:41 PM
well if you need a kidney from an A+ person, lemme know.
otherwise i *WILL* be talking to you either this summer or next spring.....
b
914werke
Feb 6 2006, 07:19 PM
QUOTE (Jake Raby @ Feb 6 2006, 04:35 PM) |
My 1911 combo makes MORE power than a stock 2.0 and runs cooler! I'll make you a sweet deal on some 1911 parts- they need to go and have been slow movers lately. |
PM sent
Allan
Feb 6 2006, 07:26 PM
QUOTE (Mueller @ Feb 6 2006, 03:21 PM) |
i'd vote for the 1911 if money is an issue*, once you get $20K in student loans, then go the monster Raby motor |
Student loans, if they are applied to 914 rebuilds they are tax deductable and void the re-payment requirement...
I'm just kidding you understand. I wish it was so.
bd1308
Feb 6 2006, 07:41 PM
a student loan huh?
hmmm....
oh and i decided that this 914 will not have a suby. I plan to make a 914 with a suby out of construction paper or something, so i can beat Paul by having the lightest 914.
Mueller
Feb 6 2006, 07:47 PM
QUOTE (bd1308 @ Feb 6 2006, 06:41 PM) |
oh and i decided that this 914 will not have a suby |
good idea, you already have hard enough time dealing with something that only uses gas and oil, I'd hate to see the problems encounted by adding water to the mix
bd1308
Feb 6 2006, 07:54 PM
gee mike,
does your 914 run well enough to drive every day?
Gint
Feb 6 2006, 07:55 PM
Joe: wha?
b |
You betcherass there is. My first 914 was a 1.8 with 96mm PC's and dual IDFs. With hydraulic lifters no less. That car was an absolute blast! It would run with 2.0's all day long.
bd1308
Feb 6 2006, 07:58 PM
hydro?
are you in the boat that says "it works great" or in the boat that says "that F'd up my engine"
b
MattR
Feb 6 2006, 08:00 PM
Subaru...
six...
Gint
QUOTE (bd1308 @ Feb 6 2006, 06:58 PM) |
hydro?
b |
Niether. Forget about that. The point is that the 1911 is a great motor and significantly better than a stock tired 1.7
jetboy
Feb 6 2006, 08:01 PM
QUOTE (Joe Ricard @ Feb 6 2006, 01:25 PM) |
Jet Boy the case does not need to be modified but the 1.7L heads do need to be cut for bigger cylinders. |
What kind of machine work needs to be done? How much does it cost for a shop to do it?
Eric Taylor
Feb 6 2006, 08:07 PM
QUOTE (MattR @ Feb 6 2006, 07:00 PM) |
QUOTE (lapuwali @ Feb 6 2006, 03:29 PM) | Subaru...
six...
Say it louder SIX
Eric
anthony
For the cost of a 2L crank and rods (maybe $200) I'd jump up to a 2056 even with 1.7L heads. Even at super sale prices a whole 1911 kit from Jake is probaby going to cost at least $2K.
If that isn't close to your budget then I'd keep an eye out for some free 1.7/1.8 engines. People around my neck of the woods seem to just give them away because nobody wants them. Maybe try and piece together a good engine from used parts and new rings, bearings, and some head work. At minimum it could be a fun project.
bd1308
Feb 6 2006, 08:39 PM
i'll see.
I think I can piece together some frankenstein contraption that should work one some level.
this 1.7 is sweet though.
I would like to go 1911, but we'll see.
Mueller, I was just playin with ya.
b
tdsmoonchild
Feb 6 2006, 09:46 PM
I'm also looking to rebuild/upgrade my 1.7. Would like about 125hp. Don't have alot of cash either. What is the advantage of having the three stud heads vs the 1.7 heads?
Especially if you get the 1.7 heads ported, polished, chambered, and bigger valves put in?
tdsmoonchild
Feb 6 2006, 09:53 PM
Also, what is this "megasquirt" thing I keep reading in the posts?
MattR
Feb 6 2006, 09:55 PM
QUOTE (tdsmoonchild @ Feb 6 2006, 07:46 PM) |
I'm also looking to rebuild/upgrade my 1.7. Would like about 125hp. Don't have alot of cash either. What is the advantage of having the three stud heads vs the 1.7 heads? Especially if you get the 1.7 heads ported, polished, chambered, and bigger valves put in? |
Spark plug angle. The 2.0 has a different spark plug angle then a standard 1.7/1.8. The 2.0 is more efficient, they say.
It also has slightly different engine tin.
MattR
Feb 6 2006, 09:56 PM
QUOTE (tdsmoonchild @ Feb 6 2006, 07:53 PM) |
Also, what is this "megasquirt" thing I keep reading in the posts? |
http://www.megasquirt.info/
megasquirt is basically a brain. Its an interface between the sensors on the engine and engine management (via laptop).
bd1308
Feb 6 2006, 10:04 PM
laptop isnt required once tuning is complete.
anthony
Feb 7 2006, 12:51 AM
QUOTE (tdsmoonchild @ Feb 6 2006, 08:46 PM) |
I'm also looking to rebuild/upgrade my 1.7. Would like about 125hp. Don't have alot of cash either. |
Forget about it. Learn to live with your 1.7 if you don't have any cash. 125hp requires a well tuned 2056 with a hot cam. You'll need carbs or an aftermarket fuel injection to run it because the stock fuel injection doesn't cut it. If you price Jakes kits you'll see that a 2056 kit starts at $3,100. If you can't get a Megasquirt system together then figure on carbs at $1000/set or an aftermaket fuel injection system at around $1500.
jetboy
Feb 7 2006, 04:11 AM
QUOTE (jetboy @ Feb 6 2006, 06:01 PM) |
QUOTE (Joe Ricard @ Feb 6 2006, 01:25 PM) | Jet Boy the case does not need to be modified but the 1.7L heads do need to be cut for bigger cylinders. |
What kind of machine work needs to be done? How much does it cost for a shop to do it? |
I guess i will quote myself again since nobody has figured out an answer yet
