Wind outside is howling, snow blowing all over the place, temperature is plummeting. No garage work tonight! So I'm getting intimate with my distributor.
First and dumbest question. If you can suck on the vacuum advance and it doesn't hold a vacuum - then it is pooched right?
Second question. The advance plate does not move smoothly. Needs lubrication as a bare minimum. How far should I tear it down.
And finally, some dumb ass let the circlip for the advance drop down into the body of the distributor. I gotta go in after it - best way? Haynes gives a procedure - any pitfalls? Anything I should do while I'm in there?
