I'm redoing all of the fuel lines with this project. I bought steel brake lines from NAPA for about $4 a piece following pelican's article. I might end up bending the lines with a tube bender instead of using a 90deg fitting.
These are the sizes i've gathered so far:
Supply: 3/8"
Return: 5/16"
Fuel Rail: 5/16"
Fuel pressure regulator: 5/16"
Fuel filter: 3/8"
I'd like to put an inline fuel pressure gauge near the fuel rail using this stuff:
1/8" fuel gauge 0-60psi
1/8" in line 3/8" adapter
How did you guys put the 3/8" inline on the fuel rail side? With a 5/16" -> 3/8" adapter? Or did you end up placing the inline gauge on the 3/8" side next to the fuel filter?
