d914
Feb 7 2006, 07:45 PM
Can't find the thread!!!
connect the two big yellows together, eliminate the others????
Was this right?????
ClayPerrine
Feb 7 2006, 08:18 PM
Under the seat, there is a heavy yellow wire, and a heavy yellow wire with a red stripe on it. Splice the 2 wires together. The rest are not necessary for the operation of the car. But you can hook up the brown wires and get the dome light to work correctly.
ClayPerrine
Feb 7 2006, 08:25 PM
Be careful.. there is one wire, a thin black one, that runs to the fuse block. It comes from the ignition fuse. If it grounds out, it will kill the ignition.
Eric_Shea
Feb 7 2006, 08:44 PM
There goes your seat heaters...
