I first tried to buy some from AA but after waiting 2 months decided to cancel my order and went and bought a brake line bending tool from my FLAPS. They had the appropriate lines (the end fittings were correct) of varying length and I found a Midas shop that put the bubble flare on the ends on the ones I had to cut. Yes I bugger up a few but using the old lines as a template (in your case you have two halves) I did great. I found that a little practice and patience it is not all that hard to do. I have even perfected small adjustments while both ends were already attached by just using my thumbs and fingers, just like the physics do when they bend forks !
Best of luck with what-ever you decide.
