Jaiden
Feb 10 2006, 12:02 PM
So I just got the gas tank out and some PO must have had a sand blasting party. I vaccumed out 2 lbs of sand!!!!!!
The chassis looks OK a little surface rust that will get POR'd but the biatch is that the old rubber fuel line snapped on the first tug of the tank. Man it's going to take a while for the gas smell to fade away.
I'm goi to be installing a sway bar now that the tank is out and hopefully replace the fuel lines in the tunnel If I can get one of my friends over to help.
Is there anything else I should do now that I have the tank out?
BigDBass
Feb 10 2006, 12:10 PM
You might want to take a look at the POR-15 fuel tank resto kit at
http://www.por15.com/PRODUCTS/COMPLETEKITS...06/Default.aspxDan
Eric_Shea
Feb 10 2006, 12:28 PM
I POR'd my entire tank while it was out... the factory paint was kinda fading and thin in areas...
I also added one of Martins GT caps and then a fiberglass hood and then pulled the motor and then............ (where's that jackstand smiley?)
Jaiden
Feb 10 2006, 12:33 PM
Eric The Engie removal is budgeted for next season so don't egg me on
This season is saftey and front suspension.
But If I break it early I might have to follow in your footsteps!!!
Eric_Shea
Feb 10 2006, 12:38 PM
Ooooooooooooh one of those sensible guys who actually plans things!!
Very cute now...
jfort
Feb 10 2006, 12:54 PM
re the fumes, I had fumes in my Mercedes, a long story. a friend had an appliance that you plug in to remove odors. i think he got it from a commercial building cleaner business. i think it makes ozone or something. anyway, after one night in the car, all the odor was gone.
maf914
Feb 10 2006, 12:56 PM
You could strip the tank down and take it to a local radiator shop. They have dip tanks that they use to clean radiators and tanks. This will remove all the loose scale and rust. Then you can seal it and paint it if needed.
Jaiden
Feb 10 2006, 01:03 PM
Proof! Ha must have been a color change at some point!!!
sean_v8_914
Feb 10 2006, 01:07 PM
relocate teh fuel pump
Trekkor
Feb 10 2006, 01:17 PM
Yes, be safe.
When you attach the new hoses, make sure they don't kink or pinch. A hose that is too long will do this.
Also, with the sway bar, there is a chance it may rub against the bottom of the tank. I shimmed my tank up a little.
KT
Jaiden
Feb 10 2006, 01:27 PM
Thanks for the heads up about the sway.
Hopefully I can get a sway soon and get the mounts welded up.
Man I love
working on this car!!!
andys
Feb 10 2006, 03:22 PM
Have your gas tank boiled out by the pro's. They'll coat the inside and paint the outside. Go to your local restoration/hotrod shop, and ask them who they use. It cost me $100 at a radiator shop that also specializes in tank resto's.
Andys
