smooth_eddy
Feb 12 2006, 02:47 AM
Saw this on eBay this eve. Last time I adjusted my valves, it seemed like I had to use every screwdriver in my tool box.
http://cgi.ebay.com/ebaymotors/VALVE-ADJUS...611939012QQrdZ1
alpha434
Feb 12 2006, 05:36 AM
looks too tall for use on a teener...
You know, get OVER the heat exchangers and BEHIND the trailing arm mount piece. And then with the 2 inches of space.... Adjust valves. 6 and 6 or 6 and 8. And then when your done cussing and spitting and throwing crap at whoever is standing around watching, at least you can sit down afterwards, sip a cola (I'm not 21) and say to yourself, at least I didn't spend 50 bucks on some tool that I couldn't use to do this.
Are teener valves 13 or 14. Mine are 14 anyway. But that might be from the PO.
tat2dphreak
Feb 12 2006, 09:27 AM
VW places carry a better, smaller solution... this one looks like something jim-bob made
it may work on an engine bench, but I'll be damned if it will fit under the car with enough room to work...
I think it's
brokeback...
type47
Feb 13 2006, 08:48 AM
the jam nut on my 1.8 is also 14mm. the only place on the whole car that a 14mm wrench is used.
Dave_Darling
Feb 14 2006, 01:16 AM
Go find yourself a ratcheting offset screwdriver. Like
this one. These are
immensely useful for valve adjusts, and also for a few other bits and pieces. Like the headlight cover retaining screws.
I use a deep-offset box-end wrench for the jam nut, and one of those ratcheting offset screwdrivers for the adjusting lug. Or at least, I use that one on the lugs I can't get my regular "stubby" screwdriver onto easily. I can't exactly call the job "easy", but it does work.
--DD
Frank Lolkema
Feb 14 2006, 05:50 AM
The tool would be of no use whatsoever, since the locknuts are 14 mm on all 914 engines (as far as I know at least) Also the VW type 4 engines use 14 mm nuts. Could that be the reason they are trying to sell it on Ebay?
hmeeder
Feb 14 2006, 06:44 AM
QUOTE |
the locknuts are 14 mm on all 914 engines |
Ummm, mine have been 13mm on 3 engines I have owned so far.
I agree that the tool is too long for a 914 application.
I have an offset screwdriver with the blade canted in 4 different orientations. No fancy ratcheting like Dave's gizmo but neither does it move without me wanting it to.
Offset Screwdriver
smooth_eddy
Feb 14 2006, 07:48 AM
My Lock nut is 13 mm I think??? Actually the Husky is a much better tool than the Craftsman Dave. It has a fine ratcheting angle and is more of a precision tool. I think I use a stubby, rt angle ratcheting, 4", 6" and maybe an 8" too. Having one more joint b/t my elbow and wrist would be nice too..... So to sum it up........Lots of screwdrivers and have another joint
tat2dphreak
Feb 14 2006, 08:51 AM
the 1.7 was 13mm, but I think 1.8s are 14mm
Tobra
Feb 14 2006, 09:12 AM
Bah, what do you even want a thing like that cluttering up your tool box. I am sure I did at least 50 valve adjusts on the bug and never bought that tool, which would be easy to use on a type I, or every one I ever saw anyway.
r_towle
Feb 14 2006, 10:28 AM
I read somwhere that a dime works well, in place of the screwdriver....
I tried it...and it makes it alot easier to get all the tools in there together...
So, I use a dime and a box wrench. I also remove the feeler guage from the stack of feeler guages and just have the one lightweight piece in my hand.
Good luck,
Rich
davep
Feb 14 2006, 11:48 AM
I'd guess that the 8mm adjusters use the 13mm nut, and the 10mm adjusters use the 14mm nut, could be wrong though.
Aaron Cox
Feb 14 2006, 12:26 PM
QUOTE (davep @ Feb 14 2006, 10:48 AM) |
I'd guess that the 8mm adjusters use the 13mm nut, and the 10mm adjusters use the 14mm nut, could be wrong though. |
i think thats correct.
Jake Raby
Feb 14 2006, 01:30 PM
These tools INCREASE difficulty of valve adjustments, especially with a 914 and the tight clearances around the valve covers...
dinomium
Feb 14 2006, 05:51 PM
I just screw em down REAL TIGHT! no problems!
of course you might want to know the farthest any of my 3 cars have gone is the end of my driveway...
