Felix and others:
Just thought it would be worth mentioning what I have already done with
a Boxster Tranny and make some comments regarding other options.
In my case I am running a Late Model Chevy V-8 (1995 350 cuin. LT-1)
in front of my 1998 Boxster tranny.
See Link:
http://www.914world.com/bbs2/index.php?act=...f=2&t=24052&hl=boxster ("Project 914-LT1")
It had many challenges but I did then and still believe that the end
product would be a great shifting, excellent gearing and dependable
transmission. At much less the cost of a 930 tranny. Mind you it is not a
strong, but very sweet to drive with the stock Boxster cable shifter.
I decided upon pioneering new ground after purchasing an Aluminum
915 tranny and considering all the associated costs; researched the 930
tranny and ZF Pantera tranny. But I was not planning to ever build the
V8 for over 450 HP and I figured IF the 901 tranny which was built for
only 100 HP could handle 300HP if not abused, then a Boxster tranny
(which was twenty five years newer, with better engineering, better
materials and modern technology) which was built for 220 HP should
also be able to handle 660 HP (3x the power) Seeing how I was only
planning to run around 350 - 450 HP I felt very comfortable making this
decision. I also spoke with some long time Porsche racers and mechanics
who also felt the Boxster would be a great tranny for the 914 V-8.
Thus may decision and commitment to the project last winter. The vehicle
was only mechanically completed late in the Fall and I did take several
local trips to check out this awesome conversion. Tranny works great
(but minor cooling issues were still be sorted before the snow and cold arrived).
It was a custom project, in which case after purchasing the tranny for
$ 2,000 including complete cable shifter set-up; designed and had my
own custom flywheel built and balanced $750; built adapter plate $400;
Pilot Bearing/spacer $ 150; Gear Reduction Starter/Ring gear set-up
including custom mounts $ 600; Kevlar Clutch Disc/Pressure Plate $750
PLUS tranny mounts; custom axles, Porsche C/V, etc. etc., etc, When it
is all said and done just the tranny conversion alone would total about
$ 5 - 6,000. Well not that it is completed; I can at least begin to enjoy
it before I decide to move ahead with a Boxster-S Six Speed tranny
conversion. (Yes the tranny's are different, but the same engineering
approach would be used to address and solve the challenges of running
the Six Speed. )
Anyway I am very pleased with the conversion and only time and abuse
will tell how strong or how long it will actually last,. But hopefully within
the next year I will get to run some street, solo, track and other events
to "check" it out. In the meantime happy motoring and all the best to the
teener community and those still “resting” on jack stands !
Allan
