I prefer the term "GOON" and sometimes answer to "hey, you wally"
Mike again beg for forgiveness for thread hijack
Time for some experimenting... enough with speculation.......
I propose the following:
1) take junky valve cover and install a "drain" fitting into the low end at a convenient location
2) epoxy a suitable thermocouple at the opening to that drain.
3) Epoxy a thermocouple on or as near to the exhaust valve guide(s) as is feasible
4) Pop two more holes in valve cover so fittings can be installed and "aimed" at exhaust valve guides
5) Close it all up and hook up your oil pump/oil cooler combo
6) while your in there, epoxy a thermocouple to the inlet and outlet of the oil cooler
Now fire up that engine, but don' t turn on the new oil supply yet. Pick a favorite throttle setting and put a brick on the pedal. While your at it, measure the ambient air temperature.
Get the "baseline" numbers of oil at bottom of valve cover before it circulates back to the pushrod tubes as well as the valve guide temps..
7) Now fun begins.. turn on your pump, and measure away... play with turning fans on and off on the oil cooler..
I just moved, so of course I got sick and tired of carting the 40 channel analog thermocouple measurement system I had bought cheap years ago (Omega) and chucked it.. so I no longer have a multichannel tc reader.. anyone on southern cal got one?
I can set up a pump and heat exchanger (got an old Moto Guzzi cooler kicking around somewhere).. But I need an old unloved valve cover.
What do I hope to prove?? Well, I'm identifying the exhaust valve as the main achilles heel of the cylinder head. If I throw lots of oil directly at it, or water indirectly as Mike proposes.. Will it make any difference.. or is the primary heat path via the cylinder fins????
Inquiring nerds need to know....
anyone got stuff to contribute to this mess??
