Jaiden
Feb 15 2006, 11:57 AM
I've tried every way I can think of except pulling it out the back through the bushing Is that the way to do it? I just can't get it to come out of the shifter hole.
I 'm doing Por15 in the tunnel and I don't want to get any on the rod.
Suggstions?
lapuwali
Feb 15 2006, 12:28 PM
You pull it back out through the bushing. No way it will come out up front. If the engine is in the car, it's possible you won't be able to completely remove it, but you can probably get enough of it out of the tunnel for your purposes. Sideshift bar will not come out of the car with the engine in place, but I now can't remember if I could sneak the tailshift rod past the mount bar or not.
Jaiden
Feb 15 2006, 01:52 PM
hmmmmmm....
I think I'll just zip tie it up off the bottom and Por-15 away!!
Thanks!
