QUOTE (Mike D. @ Feb 16 2006, 06:49 PM) |
You should be able to find the cable under the small access panel on the center tunnel right next to the pedel. small flat head screw holds the panel in place. take a flash light and a mirror.... Good Luck |
QUOTE (MW 914 @ Feb 16 2006, 06:38 PM) |
You best get 'er done by Saturday morning!! |
QUOTE (SLITS @ Feb 16 2006, 06:51 PM) |
Vell, it should be hiding in the tunnel......take cable loose at carbs and push it all the way into the sheath....then crawl on your belly like a reptile (desert pun intended) and try to get your head near the front of the tunnel to take a look-see in lieu of that....a flashlight and a mirror will work too! Yes, you can use your wife's makeup mirror, but you can't put any lipstick on. |
QUOTE (Flat VW @ Feb 16 2006, 06:59 PM) |
I've got Shaggy on it! John P.S. Report back soon. |
QUOTE (SLITS @ Feb 16 2006, 07:05 PM) | ||
Let me know how many parts I'm gonna have to FedEx O'Nite to you |
QUOTE (Flat VW @ Feb 16 2006, 11:00 PM) |
Change of oil and a good bath and we are ready. John |
QUOTE (gregrobbins @ Feb 17 2006, 04:24 PM) |
SHAGSTER Way to go, now when are we going to see you in the White Lightening out at some autocross and DE events? |
