yellowbird rs
Feb 17 2006, 12:28 PM
What if I have the Porsche 911 strut with the 3 inch bolt spacing (for M calipers) but want to be use it with the Volvo calipers intead of the M? Will the calipers fit over the vented Porsche rotors? What model car has the ones that will fit. The parts counter guys always want make, model, year, etc for the calipers to let me use the 911 rotors (290mm x 20mm)
john rogers
Feb 17 2006, 12:46 PM
There are two Volvo calipers, one for solid rotors and one for vented rotors. Do an internet search on Volvo caliper conversions and on the Datsun (or similar board) there are lots of info.
yellowbird rs
Feb 17 2006, 01:25 PM
thanks John, I allredy search and find all the mods. and a lot of info. but can't find the answer, some were someone said their are the same calipers for vented or solid rotors jus change the pads ?????? and have a set of new fronts rotors so i don't want to go wrong w/the calipers.
Do I need vented or solid volvo calipers???
SLITS
Feb 17 2006, 01:41 PM
ACEI's catalog listed them with the rebuiler's number followed by "V" for vented and NV for non-vented (solid). I doubt they are the same. The vent in the top of the caliper would indicate which they were for...vent = where the rotor rides and it's width.
Aaron Cox
Feb 17 2006, 01:43 PM
QUOTE (SLITS @ Feb 17 2006, 12:41 PM) |
ACEI's catalog listed them with the rebuiler's number followed by "V" for vented and NV for non-vented (solid). I doubt they are the same. The vent in the top of the caliper would indicate which they were for...vent = where the rotor rides and it's width. |
I have one of each from mista slits
its true! they bolt on and only need a washer to center them on the rotor....
but they need a way bigger rotor to utilize the whole pad.....
i was inquiring about offsetting the mounting holes to make them sit lower on to the rotor
SLITS
Feb 17 2006, 01:50 PM
QUOTE (Aaron Cox @ Feb 17 2006, 12:43 PM) |
QUOTE (SLITS @ Feb 17 2006, 12:41 PM) | ACEI's catalog listed them with the rebuiler's number followed by "V" for vented and NV for non-vented (solid). I doubt they are the same. The vent in the top of the caliper would indicate which they were for...vent = where the rotor rides and it's width. |
its true! they bolt on and only need a washer to center them on the rotor.... but they need a way bigger rotor to utilize the whole pad.....
i was inquiring about offsetting the mounting holes to make them sit lower on to the rotor |
You're an effin engineer in training.....figure it out...If the caliper hat doesn't hit the rotor who gives a flip....grind away....and if you grind to much of the vent for clearance 'cause you want them real low, maybe the caliper will split in half. Work it out slide-rule boy!
yellowbird rs
Feb 17 2006, 01:54 PM
QUOTE (Aaron Cox @ Feb 17 2006, 11:43 AM) |
hey! Can you post a side by side pics. also the measures of the thickness of the rotors spacing and the thickness of the pads.
Aaron Cox
Feb 17 2006, 01:56 PM
look at sklines shalom with the vented volvo's..... it only uses the top 2/3 of the rotor..... and about a 1/4" of pad overhang
so... bigger rotor, or sit the caliper further down onto the rotor.....
Mueller
Feb 17 2006, 02:43 PM
Bernie said these are from a 700 series Volvo, all of them should be vented, you'll also have to do some mickey mouse engineering to overcome the dual circuit of the Volvo calipers...some have used lines to create a "T", I've posted diagrams to making an adapter.....
SLITS
Feb 17 2006, 02:57 PM
740 Series
'91-'92 Bendix
'91-'92 Girling w/o ABS
'91-'92 Girling w/ ABS
'84-'90 Bendix w/o ABS dual inlet
'84-'90 Girling w/ABS single inlet
'84-'90 Girling w/o ABS dual inlet
'84 Girling - aluminum casting
760 Series
'83-'90 Bendix w/o ABS dual inlet
'83-'90 Bendix w/ ABS single inlet
'83-'90 Girling w/ ABS dual inlet
'83-'84 Gilrling - aluminum casting
780 Series
'87-'90 Bendix single inlet
'87-'90 Girling single inlet
Eric_Shea
Feb 17 2006, 03:47 PM
Tell us about your engine.
Aaron Cox
Feb 17 2006, 04:27 PM
they are 240 series..... iirc
Porcharu
Feb 17 2006, 04:31 PM
You want the calipers from a 240 series Volvo. Try an 81' 240 GLT I know they have the vented rotors. The calipers in Mikes pic are the 240's.
SLITS
Feb 17 2006, 06:27 PM
240 / 260 Series
'88-'93 w/ ABS
'88-'93 w/o ABS
'75-'87 Girling w/ solid rotor
'75-'87 Girling w/ vented rotor
'75 ATE w/ solid rotor
'75 ATE w/ vented rotor
Twystd1
Feb 17 2006, 06:31 PM
I will bring a set of em to Sharp's so you guys can look at em...
Twystd1
SLITS
Feb 17 2006, 06:35 PM
QUOTE (Twystd1 @ Feb 17 2006, 05:31 PM) |
Twystd1 |
I am just breathless with anticipation.......
Eric_Shea
Feb 17 2006, 06:50 PM
QUOTE |
I will bring a set of em to Sharp's so you guys can look at em... |
Ohh, I'm moist. Might even get a plane ticket now!
J P Stein
Feb 17 2006, 06:56 PM
OK, learn me something.
What is the advantage of the Volvo claiper over the M caliper?
SLITS
Feb 17 2006, 07:05 PM
4 piston / more swept area?
Twystd1
Feb 17 2006, 07:07 PM
OK,
Slits..
There new in box..
Ya want em???
There yours.
Eric only gets the cardboard...
Twy
Eric_Shea
Feb 17 2006, 07:09 PM
Slits and I can share...
SLITS
Feb 17 2006, 07:14 PM
You want the right or left?
Eric_Shea
Feb 17 2006, 07:56 PM
Top please...
yellowbird rs
Feb 18 2006, 02:44 PM
ok I want bouth L&R front 240 calipes, where can I found them???
J P Stein
Feb 18 2006, 03:11 PM
QUOTE (SLITS @ Feb 17 2006, 05:05 PM) |
4 piston / more swept area? |
Which translates to........?
If you say better braking, I'm gonna
Eric_Shea
Feb 18 2006, 05:04 PM
QUOTE |
Which translates to...... |
Better Braking!
(well, it sounds cool. 4 pot, 4 pot, 4 pot... not what you're thinking Korijo. Dave's more like Will work 4 pot, Will work 4 pot...)
J P Stein
Feb 18 2006, 05:09 PM
Eric_Shea
Feb 18 2006, 05:38 PM
Just wanted to see if I could make ya hurl
Aaron Cox
Feb 18 2006, 09:02 PM
JP, they weigh more than an M but way less than an unloaded A caliper.....
jim_hoyland
Feb 18 2006, 09:46 PM
Saw them in the boxes at Joes, but didn't get the story of why they dont fit the rotor. Can the volvo rotor be used to overcome the problem ?
Aaron Cox
Feb 18 2006, 09:47 PM
QUOTE (jim_hoyland @ Feb 18 2006, 08:46 PM) |
Saw them in the boxes at Joes, but didn't get the story of why they dont fit the rotor. Can the volvo rotor be used to overcome the problem ? |
no way jose....
needs a custom rotor..... or caliper modification
Aaron Cox
Feb 18 2006, 10:09 PM
yellowbird rs
Feb 19 2006, 08:04 AM
Aaron, Do you have the pair for vented rotors? Do you sell them?
How much??
anzuresags@att.net.mx
Aaron Cox
Feb 19 2006, 11:32 AM
QUOTE (yellowbird rs @ Feb 19 2006, 07:04 AM) |
Aaron, Do you have the pair for vented rotors? Do you sell them? How much?? anzuresags@att.net.mx |
go to your local FLAPS (friendly local autoparts store) and say youd like a pair of vented volvo 240 calipers......
90 each no core ...
ChicagoChris
Feb 19 2006, 01:57 PM
Aaron...I went to my FLAPS and ran into a bit of a problem. There is no 240. There is a series 240 but they want to know which version of the 240 series to look at. Their computers don't list a 240 and they won't think past what they read. So which of the 240 series cars did you buy? (year included)
Aaron Cox
Feb 19 2006, 02:00 PM
i know 86 240's were vented....
but i wont run these until i sort out the following....
A ) machining the mounting ears to sit farther in on the rotor
B ) bigger rotor if A) cant be done
C ) pad options.....
ChicagoChris
Feb 19 2006, 02:07 PM
'86 240 ok then.
Are the pads to big (tall) for the rotors. ie will they hang over the top?
Aaron Cox
Feb 19 2006, 02:09 PM
QUOTE (ChicagoChris @ Feb 19 2006, 01:07 PM) |
'86 240 ok then.
Are the pads to big (tall) for the rotors. ie will they hang over the top? |
YES. its because the CALIPER doesnt sit far enough down on the rotor, thus not utilizing the bottom 1/3 of the rotor, and leaving .25" of pad overhang.....
so these sit on my shelf till then
ChicagoChris
Feb 19 2006, 02:10 PM
OK re read your post. What is the rotor diameter of the 240? Will the pads follow the rotor properly even if you bring the caliper down?
Aaron Cox
Feb 19 2006, 02:13 PM
QUOTE (ChicagoChris @ Feb 19 2006, 01:10 PM) |
OK re read your post. What is the rotor diameter of the 240? Will the pads follow the rotor properly even if you bring the caliper down? |
i lost the dimensions many a year ago im sure a simple google search would suffice, let me know what ya find out.
also, SOME 15" wheels wont clear, and you have to sand/grind the outside edge of the caliper (very very minimal)
just food for thought
ChicagoChris
Feb 19 2006, 02:19 PM
I will be running 15 FUCHS over 911 vented. I'll keep my eye out for when you do it. I have a month or so till I have to start re-assembling the car.
Aaron Cox
Feb 19 2006, 02:23 PM
these have been on my shelf for a year now......youll be waiting, unless you pioneer it first
they are lighter than A calipers tho
ChicagoChris
Feb 19 2006, 03:56 PM
I might just pioneer. The bigger piston size in the M caliper is worth a bit more brake but the pads are the same. My car is getting preped for the Targa NewFoundland so add a passenger, a cage, baggage, and electronics. I will be heavy all the time. The extra pad would be extra piece of mind.
Aaron Cox
Feb 19 2006, 04:15 PM
QUOTE (ChicagoChris @ Feb 19 2006, 02:56 PM) |
I might just pioneer. The bigger piston size in the M caliper is worth a bit more brake but the pads are the same. My car is getting preped for the Targa NewFoundland so add a passenger, a cage, baggage, and electronics. I will be heavy all the time. The extra pad would be extra piece of mind. |
cool. figure out the caliper mod and we got a winner
yellowbird rs
Feb 19 2006, 05:48 PM
QUOTE (ChicagoChris @ Feb 19 2006, 12:10 PM) |
263mm x 22mm
ChicagoChris
Feb 19 2006, 06:24 PM
QUOTE (yellowbird rs @ Feb 19 2006, 03:48 PM) |
263mm x 22mm |
Porsche 911 SC
282.5 x 20.5
smaller thicker rotor with longer caliper ears. Might be 1 too many problems then they are worth.
Aaron Cox
Feb 19 2006, 06:58 PM
so an SC rotor solves the problem? cant be that simple...
its the caliper ears that make it stick out to far... i think the aftermarket rotor used was 11.25 .....
ChicagoChris
Feb 19 2006, 07:18 PM
I don't know what you were using but the measurement sounds ok. Mine were like 11 3/16.
But I don't know if that solves the problem. The thickness is good (22 vs 20) but the volvo is the smaller diameter. So the hangover is in the ears, but what do you have for Volvo pad measurement? Have you put the 914 pad against the Volvo? How do they compare top to bottom?
bernbomb914
Feb 21 2006, 12:37 AM
I dont know what all the fuss is about. The volvo pad hangs over so grind the lining off so that it does not. You will still have much more brake surface than any two pot caliper. I have had mine for over two years and they work great. much better than stock. and they are very cheap at the pick a part.
Bernie
BRAVE_HELIOS
Aug 20 2011, 01:26 PM
QUOTE(bernbomb914 @ Feb 21 2006, 12:37 AM)
Bernie <!-- emo&:deadhorse: --><img src='http://www.914world.com/bbs2/html/emoticons/dead horse.gif' border='0' valign='absmiddle' alt='dead horse.gif'><!-- endemo -->
Bernie,
Would you mind giving as much detail as possible regarding the Volvo front caliper swap... such as what rotors did you use and how did you deal with the two line ports on the Volvo unit.
Thank.
Tony
