I'm looking into how sway bars are made and need information on the material that is used.
Are the bars hollow or solid?
What material is typically used?
If bars are hollow, what wall thickness is commonly used?
QUOTE (Dave_Darling @ Feb 17 2006, 08:18 PM) |
I don't remember the alloy, but I believe it is one of the mild steels. A google search should turn up spring rate calculations for torsion bars, which should be pretty similar to those for sway bars (once you factor in the different lengths). I assume that's why you need the configuration and composition of the bars, yes? |
QUOTE (Mueller @ Feb 17 2006, 11:27 PM) |
speedway engineering ......this is one of those items you are better off biting the bullet and fabricating an assembly from items you can buy off the shelf (see link above) |
QUOTE (Borderline @ Feb 18 2006, 08:58 AM) |
Carroll Smith in his book Tune to Win states that mild steel sway bars are just barely adequate. The failure mode is that the bar will yield and take a set. When that happens your suspension will be preloaded one way or another and your corner weights will be all off. Smith recommends using 4130 seamless tubing and heat treating to Rc34-38. I made my own front bar from a length of solid 4xxx series solid bar. I'll let you know how it works when the hell hole gets repaired and the jack stands are removed. Have fun Bill |
