QUOTE (grantsfo @ Feb 17 2006, 10:03 PM) |
I have spoken with a few people about 2.4 911 E engine with carbs and so far reccomendation is to go without an oil cooler to start. General concensous is that as long as I dont run the engine too lean it should stay cool enough. |
QUOTE (Aaron Cox @ Feb 17 2006, 09:05 PM) | ||
most people say 170hp and over.... it cant hurt. more oil and more cooling ability is always a good thing. are you going to track it? run it on hot days? and please use engine tin..... id do it.... |
QUOTE (trekkor @ Feb 17 2006, 10:33 PM) |
On mine all was well until that one time at Marina when we had all those "fun-runs" on a hot day. the real test came at Thunderhill when the temps kept climbing north of 245°. Now the cooler is in. No problems anymore. 180° and 210° on the track. No tin... KT |
QUOTE |
sit in traffic. stay stationary... |
QUOTE (trekkor @ Feb 17 2006, 10:56 PM) | ||
*NEWSFLASH* This just in- Traffic has slowed out of turn 4 and it's stop and go out of 7. Expect slower lap times until you exit 11. Ahhhhh! KT |
QUOTE (J P Stein @ Feb 18 2006, 06:19 AM) |
I would suggest: Remove the air deflectors and do Anderson's recommended cuts on them.....and put em' back on, of course ... |
QUOTE (Headrage @ Feb 18 2006, 07:18 AM) |
My 2.7 doesn't have an external cooler. 100 degrees in the summer over the grapevine. But it does have the tin and everything will be nice and clean. |
QUOTE (grantsfo @ Feb 18 2006, 07:46 AM) |
As usual great debate and you have got me reconsidering. Thanks! |
QUOTE |
The 2.4E is a borderline deal. |
QUOTE (J P Stein @ Feb 18 2006, 04:28 PM) |
James: I don't know which engine you have. It is possible on a 6... |
QUOTE (thesey914 @ Feb 18 2006, 10:36 AM) | ||
This is for a carbed 2.4 six that I'm preparing to install. I thought that removal of the tin was obstructed by the crankcase bolts. Removal is to perform the tinware mods as described in Bruce Andersons book. |
QUOTE (fiid @ Feb 18 2006, 08:51 AM) |
A 911 motor is some expensive $#!+ to rebuild - I'd add a cooler as extra insurance/longevity. Sorry to I also would run carbs, but don't take that as a - it's just my 2 cents. |
QUOTE (J P Stein @ Feb 18 2006, 07:45 PM) |
If you remove the FG shroud, you can access & remove the air deflectors to make your cuts....spring clips are all that hold them on.....they come out the bottom so headers could be a problem. |
