ventilator01
Feb 19 2006, 12:09 PM
Im to the point in my teardown that I need to remove the flywheel, this part is not covered in the video I bought, do I need to make any reference markings before I start unbolting?
Thx
steve
tat2dphreak
Feb 19 2006, 01:00 PM
no ref. marks unless you are going to re-use the press. plate... (not recommended, unless it's already "new")
just take off the 6 bolts to remove the PP, then 5 to take off the flywheel(use a breaker bar, they are on tight)... use new bolts and crush washer when putting the flywheel back on
rhodyguy
Feb 19 2006, 01:13 PM
there is a flywheel lock tool that helps. can't find mine right now so no picture. they're shown at pelican. you will need to get the spline alignment tool for reassem. most bug shops will have them, pretty cheap too. a compressor and impact gun makes short work of the removal.
k
tat2dphreak
Feb 19 2006, 01:34 PM
QUOTE (rhodyguy @ Feb 19 2006, 02:13 PM) |
k |
I just jab a screwdriver though the holes in the flywheel...
mack914
Feb 19 2006, 01:39 PM
I had to apply a little heat to those bolts....to get them loose
rhodyguy
Feb 19 2006, 01:40 PM
you're an animal wayne
. i think the fwl was like $7 at ovals (a local bug place). it's very helpful upon reassem. holding the screwdriver just so, and torqueing things down, is just too much work in my book. mashed and bloddy fingers aren't part of the program.
k
tat2dphreak
Feb 19 2006, 01:50 PM
jab the screwdriver through the hole in the case... no work at all...
no local bug place anymore
KevinP
Feb 19 2006, 02:01 PM
Steve,
I always make it a habit to index everything. if your going to reuse the pressure plate make sure you index it to the flywheel. i don't know the reason on your teardown but you can never go wrong on indexing anything. May even save you from a rebalance of the crank depending on the reason the flywheel is coming off.
Hope this helps, I think most will agree with me.
KP
ventilator01
Feb 19 2006, 02:46 PM
Thx everyone, I have it off, I had to use about a four foot piece of pipe slid up onto my ratchet, then holding a screwdriver into one of the larger holes in flywheel, was not easy.. but didnt break anything.
Kevinp, pm sent to you
thx
steve
