is it necessary to "bleed" the proportioning valve?
if so, i guess you just do the right rear, left rear, then prop valve?
thanx guys,
roger
QUOTE (r_towle @ Feb 20 2006, 05:49 PM) |
yah cant bleed it. What you need to do is push the air through it and get it out at the calipers... It needs about 750 psi to get through the valve...(I think) so here is what I do. bleed each corner in the correct sequence RR, LR, RF, LF do that twice. Then once you have pedal, push really hard on the pedal for one to two minutes...you will feel each bubble push through the valve...one you have done that, do the calipers again... You might need to do this whole thing twice to get the bubbles out... Rich |
QUOTE (Eric_Shea @ Feb 21 2006, 08:05 AM) |
methods to force the trapped air out of the p-valve. |
QUOTE |
i see that the outer has a lock nut on the adjuster but can/should anything be done on the inner adjuster???? or just tighten it and call it good? |
QUOTE (Eric_Shea @ Feb 21 2006, 09:24 AM) | ||
They 'both' need to be adjusted properly. There's no set-it-and-forget-it back there. Adjust both to .004... let me know if you need details on the procedure |
QUOTE |
I thought it was just me facing this challange....that friggen' pvalve |
QUOTE (Eric_Shea @ Feb 21 2006, 08:42 AM) | ||
Ray, are you lisenced? If so, have Sal let you take it for a week and then come back for a final bleed of the rears. |
QUOTE (Eric_Shea @ Feb 21 2006, 09:55 AM) |
Roger... The inner has a cap that will strip when you try to remove it Readers Digest: 1. Take your handbrake cable off. 2. Go through the hole in the trailing arm with a long extension and a 4mm hex socket. 3. 'Attempt' to remove the cap. (pray, swear, etc.) 3a. Remove the caliper to spin the cap off with a cold chisel 3b. Your prayers were answered and the cap came off, leave the caliper on and begin the adjusting process. 4. Use the same 4mm to run the 'gear' inside. Clockwise will push the piston 'out' toward the caliper (the adjuster is the cut the same as the front or a normal screw but, because it's gear driven everything on the inner adjuster is backward) 5. Set the clearance to .004. If you don't have a gauge then a business card should suffice. 6. Buy a pair of 10mm caps from PP and 'do not' replace the 4mm hex cap. there is simply not enough surface area in the 4mm hex to overcome the rusted thread engagement of the bore. 7. Repeat on the other side. Fronts, back off the 13mm nut and adjust as normal with a 4mm hex. Counter closckwise will push the piston toward the pad. |
QUOTE (Eric_Shea @ Feb 21 2006, 10:05 AM) |
no... there's a gear in that bore, once you get the cap off. I should say 'there's supposed to be a gear in that bore'. We no longer ship calipers with the gear because too many were sent to us w/o gears. There came a time when I was down to 2 gears and 40 cores. No lock nut. |
QUOTE (MattR @ Feb 21 2006, 11:04 AM) |
When I first read the title, I thought it said "bleed a prototipo" my steering wheel doesnt bleed |
QUOTE |
I thought I was trippin' , yo. |
