pete-stevers
Feb 21 2006, 11:51 AM
i will be running my lines soon.....the sooner the better...but what thermostat should i use
i am running a 3.0 on the street....to "chicken" Bawk...bawk" to run it on the track
so recomendations on a thermostat....revisited
Aaron Cox
Feb 21 2006, 11:52 AM
-12 Mocal....
Eric_Shea
Feb 21 2006, 12:51 PM
How about a 911 thermostat?
pete-stevers
Feb 21 2006, 12:55 PM
where would i source a 911 thermostat?
any body got one
Allan
Feb 21 2006, 12:58 PM
Eric_Shea
Feb 21 2006, 01:13 PM
Wrong part. I'm assuming he needs the front cooler thermostat.
PP in the 911 Classifieds is the most active on the web.
IronHillRestorations
Feb 21 2006, 01:52 PM
On all but one of the cars I've done, I put a Mocal thermostat with -12AN fittings on the lower firewall.
The last car I built we had a smaller cooler under the rear trunk floor without a thermostat. It's close enough to the engine that the internal thermostat will be enough.
J P Stein
Feb 21 2006, 01:53 PM
QUOTE (Eric_Shea @ Feb 21 2006, 11:13 AM) |
PP in the 911 Classifieds is the most active on the web. |
Actually, the right part.... in a way. Troutman will supply you with one of those inside a housing of their own manufacture
for use as an Aux cooler thermostat. -12 or -16 fittings.
Eric_Shea
Feb 21 2006, 02:59 PM
QUOTE |
Troutman will supply you with one of those inside a housing of their own manufacture for use as an Aux cooler thermostat. -12 or -16 fittings. |
I've got one of those I'll send you Steve... I don't think it's of much use unless you have a troutman housing but the offer's there. Ask JP to help you set it up...
