Full Version: Things to do before WCC 06
DNHunt
OK, what do you have to get done to your car before you can make it to Portland?
biggrin.gif 1) change brake fluid
2) change oil
Oh ya, lend a hand to guys who have a longer list
Dave
double-a
1. wait for paint guys to finish
2. put it back together
~a
r_towle
Design and build a functional teleportation system large enough for both me and my car...
Rich
QUOTE (DNHunt @ Feb 21 2006, 11:37 AM)
2) change oil
well, it's running great right now, so if i just put the 3.6L on hold, i'll be able to get away with an oilchange and a gallon of windshield cleaner fluid ...
but knowing me, i'm probably tear it down completely just in time for the WCC ...
screwy.gif Andy
QUOTE (r_towle @ Feb 21 2006, 11:45 AM)
interestingly enough, i just read a book about that ...
they were talking about teleporting a whole car and what it would take.
so far, they can only teleport a few photons at once (which in itself is pretty amazing), so my bet is you're SOOL ...
cool_shades.gif Andy
r_towle
QUOTE (SirAndy @ Feb 21 2006, 02:49 PM)
photons are better than nothing....is progress...
I think I would settle for a virtual presence...full 3D holographic presence...
that would also be cool, and that works..kinda
Rich
MartyYeoman
QUOTE (double-a @ Feb 21 2006, 11:42 AM)
2. put it back together...
BigDBass
1. Get a 914.
2. Get 914 running.
3. Become a dad.
4. Maybe next year!
gopack
QUOTE (BigDBass @ Feb 21 2006, 12:34 PM)
1. Get a 914.
2. Get 914 running.
3. Become a dad.
4. Maybe next year!
Might be easier to BUY a running one Dan!
Just a thought!
rick 918-S
Need to do a complete engine rebuild, Transaxle (handled as soon as Phantom Grip comes through... WTF.gif mad.gif ) Make a complete new exhaust including heat exchangers, send the entire exhaust out for coating, Add sway bars, clean and paint the chassis, Repair some body flaws, fix some wear and tear in the interior, new tires at a minimum, but I really want new wider wheels and tires, is that enough?
DNHunt
Rick
JB Weld, toothpicks and dental floss. If that don't work, duct tape. Otherwise get a new spring. How's the valve? For that matter how's the piston? I feel for ya
Dave
ejm
Toast
Fix this:
Toast
New brakes
Fix Horn
Save $$$$$
rick 918-S
QUOTE (DNHunt @ Feb 21 2006, 01:54 PM)
Rick
Dave
I located a set of springs at 928 int. wavey.gif (Hi Mark) I filled the port with sovent and had a slight leak past the valve. So the valve may be fudged. The pistons are fine. The bores are fine. I have a gasket set (soon)
Here's my problem, I'm such a control freak about who works on my stuff, I'm having a real problem trusting a machine shop to work on my heads. I think I located an experienced guy but he's 180 miles away and doesn't readily return calls...
I've had some real bad experiences with machine shops.
Gint
I just adjusted the carb on the new 914 so...
To be fair, I should really repalce those pesky push rod tube seals. But it's not necessary.
Porcharu
Fix rusty floors, mount seats lower, install Subaru engine and transmission, tune SDS system and change brake fluid av-943.gif
Allan
My motor should be done this week so that will be out of the way. The tranny has a fresh rebuild so I don't need to deal with that.
I would like to have the 5 lug conversion, paint and interior done before July.
Dr. Roger
man oh man....
finish the suspension/brakes.
get fattie wheels tires installed and spaced correctly
finish rewiring the car (this should have been priority one...)
get flares on corectly
paint???? maybe... (note to self...play lotto tonight)
shake down the cooling system
insure
and go!
TurtleGirl
Crap!!! The counter's up already?!?!
rick 918-S
QUOTE (TurtleGirl @ Feb 21 2006, 05:29 PM)
wavey.gif give us an update. How's the list coming?
Series9
Make this into a running car:
Series9
Make this into a car carrier:
jimtab
QUOTE (Toast @ Feb 21 2006, 02:11 PM)
Fix this:
Melba, you just gotta change that braille style parking mode you use.... happy11.gif
jimtab
Oh yeah, I just sent my door handles to Fla. to be fixed both broke the same week....I know, it isn't very interesting but I think that's all...ok, maybe flush the old brake fluid out of the car and pour in new from above...oh yeah, and flush the coolant on the backroads before we leave for Portland.....
ThinAir
1) Find a tow dolly to borrow so I don't have to rent from U-Haul (since my wife is coming along we're towing behind the VW camper instead of driving the 914)
2) Wash the car
3) Make reservations (sorry Craig, I've been busy!)
shaggy
rebuild 2.0
find exhaust
remove engine fomr '72 (1.7)
change engine and clutch
add sway bar
rebuild brake calipers
fine tune car
-shag
